Raspberry Pi Camera IO Issue... SOLVED
by dpowrie on Thu Feb 04, 2016 11:42 pm
Hi all,
I solved the issue below by increasing the resolution in Motion to 720p. Does anyone know the minimum resolution as I am installing this in a bandwidth poor environment!
I've followed all the steps to get my RPi camera streaming to Adafruit.io https://learn.adafruit.com/cloud-cam-co ... ity-camera
It seems to work from the RPi end - I get 'camera daemon started and is pushing images to Adafruit IO', a camera_feed is generated in Adafruit IO, the (?) activity stream suggests that there is more data coming in than previously, but I cannot view the video in Adafruit.IO.
Is there any suggestions / solutions?
dpowrie
Re: Raspberry Pi Camera IO Issue... SOLVED
by justterry on Fri Feb 05, 2016 9:33 pm
having similar problem. i get mutiple feeds all called camera_feed and I cant attach them to an image box I hit create and it just sitts there
justterry
