Can't subscribe to more than one feed
by thnikk on Mon Feb 08, 2016 2:50 am
Hello!
I can't subscribe to more than one feed. I've been troubleshooting for a while and I'm completely lost. The code (and the 2subs example code) both work fine and connect ONLY IF the feeds I'm using don't exist on adafruit.IO. I'm also able to connect with one just fine. Here's my code:
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
/************************* WiFi Access Point *********************************/
#define WLAN_SSID       "SSID"
#define WLAN_PASS       "Password"
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883                   // use 8883 for SSL
#define AIO_USERNAME    "Username"
#define AIO_KEY         "Key"
/************ Global State (you don't need to change this!) ******************/
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
// or... use WiFiFlientSecure for SSL
//WiFiClientSecure client;
// Store the MQTT server, username, and password in flash memory.
// This is required for using the Adafruit MQTT library.
const char MQTT_SERVER[] PROGMEM    = AIO_SERVER;
const char MQTT_USERNAME[] PROGMEM  = AIO_USERNAME;
const char MQTT_PASSWORD[] PROGMEM  = AIO_KEY;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, MQTT_SERVER, AIO_SERVERPORT, MQTT_USERNAME, MQTT_PASSWORD);
/****************************** Feeds ***************************************/
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
// Setup a feed called 'onoff' for subscribing to changes.
const char COLOR_FEED[] PROGMEM = AIO_USERNAME "/feeds/color";
Adafruit_MQTT_Subscribe color = Adafruit_MQTT_Subscribe(&mqtt, COLOR_FEED);
const char PHOTOCELL_FEED[] PROGMEM = AIO_USERNAME "/feeds/photocell";
Adafruit_MQTT_Subscribe photocell = Adafruit_MQTT_Subscribe(&mqtt, PHOTOCELL_FEED);
/*************************** Sketch Code ************************************/
// Bug workaround for Arduino 1.6.6, it seems to need a function declaration
// for some reason (only affects ESP8266, likely an arduino-builder bug).
void MQTT_connect();
  Serial.begin(115200);
  delay(10);
  Serial.println(F("Adafruit MQTT demo"));
  // Connect to WiFi access point.
  Serial.println(); Serial.println();
  Serial.print("Connecting to ");
  Serial.println(WLAN_SSID);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println();
  Serial.println("WiFi connected");
  Serial.println("IP address: "); Serial.println(WiFi.localIP());
  // Setup MQTT subscription for onoff & slider feed.
  mqtt.subscribe(&color);
  mqtt.subscribe(&photocell);
uint32_t x=0;
  // Ensure the connection to the MQTT server is alive (this will make the first
  // connection and automatically reconnect when disconnected).  See the MQTT_connect
  // function definition further below.
  MQTT_connect();
  // this is our 'wait for incoming subscription packets' busy subloop
  // try to spend your time here
  Adafruit_MQTT_Subscribe *subscription;
  while ((subscription = mqtt.readSubscription(5000))) {
    // Check if its the onoff button feed
    if (subscription == &color) {
      Serial.print(F("color: "));
      Serial.println((char *)color.lastread);
    // check if its the slider feed
    if (subscription == &photocell) {
      Serial.print(F("photocell: "));
      Serial.println((char *)photocell.lastread);
  // ping the server to keep the mqtt connection alive
  if(! mqtt.ping()) {
    mqtt.disconnect();
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  uint8_t retries = 3;
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
       Serial.println(mqtt.connectErrorString(ret));
       Serial.println("Retrying MQTT connection in 5 seconds...");
       mqtt.disconnect();
       delay(5000);  // wait 5 seconds
       retries--;
       if (retries == 0) {
         // basically die and wait for WDT to reset me
         while (1);
  Serial.println("MQTT Connected!");
I'm not sure if it's just something I'm missing or if it's a bug. Any help would be greatly appreciated!
thnikk
Re: Can't subscribe to more than one feed
by adafruit2 on Mon Feb 08, 2016 6:41 pm
if you turn on verbose MQTT output whats the debug console say?
adafruit2
Site Admin
by thnikk on Mon Feb 08, 2016 8:34 pm
adafruit2 wrote:if you turn on verbose MQTT output whats the debug console say?
I'm sorry, how do I do this?
thnikk
by adafruit2 on Mon Feb 08, 2016 9:04 pm
adafruit2
Site Admin
by thnikk on Mon Feb 08, 2016 11:15 pm
Thanks! Here it is:
Connecting to <ssid>
WiFi connected
IP address:
10.0.0.46
Added sub 0
Added sub 1
Connecting to MQTT... Connecting to: io.adafruit.com
Connect result: 0
Connection failed
MQTT disconnect packet:
à [0xE0],   [0x00],
Connection failed!
Unable to send disconnect packet
Connect result: 1
SERVER GENERATING CLIENT ID
MQTT connect packet:
 <removed for username and AIO key>
sendPacket returned: 64
Read packet:     [0x20],   [0x02],   [0x00],   [0x00],
MQTT subscription packet:
‚ [0x82],   [0x17],   [0x00],   [0x00],   [0x00],   [0x12], t [0x74], h [0x68],
n [0x6E], i [0x69], k [0x6B], k [0x6B], / [0x2F], f [0x66], e [0x65], e [0x65],
d [0x64], s [0x73], / [0x2F], c [0x63], o [0x6F], l [0x6C], o [0x6F], r [0x72],
  [0x00],
sendPacket returned: 25
Read packet:   � [0x90],   [0x03],   [0x00],   [0x00],   [0x00],
SubAck:   � [0x90],   [0x03],   [0x00],   [0x00],   [0x00],
‚ [0x82],   [0x1B],   [0x00],   [0x01],   [0x00],   [0x16], t [0x74], h [0x68],
d [0x64], s [0x73], / [0x2F], p [0x70], h [0x68], o [0x6F], t [0x74], o [0x6F],
c [0x63], e [0x65], l [0x6C], l [0x6C],   [0x00],
sendPacket returned: 29
Read packet:   2 [0x32],   [0x1D],   [0x00],   [0x12], t [0x74],
SubAck:   2 [0x32],   [0x1D],   [0x00],   [0x12], t [0x74],
Failed to subscribe
à [0xE0],   [0x00],
Connect result: 1
‚ [0x82],   [0x17],   [0x00],   [0x02],   [0x00],   [0x12], t [0x74], h [0x68],
  [0x00],
Read packet:   � [0x90],   [0x03],   [0x00],   [0x02],   [0x00],
SubAck:   � [0x90],   [0x03],   [0x00],   [0x02],   [0x00],
‚ [0x82],   [0x1B],   [0x00],   [0x03],   [0x00],   [0x16], t [0x74], h [0x68],
Failed to subscribe
à [0xE0],   [0x00],
Soft WDT reset
ctx: cont
sp: 3ffefb70 end: 3ffefd60 offset: 01b0
>>>stack>>>
3ffefd20:  00000001 3ffeeae8 3ffeecf8 402019b6
3ffefd30:  3fffdc20 00000000 3ffeed24 402019fc
3ffefd40:  3fffdc20 00000000 3ffeed24 40203735
3ffefd50:  00000000 00000000 3ffeed40 40100114
<<<stack<<<
thnikk
by adafruit2 on Tue Feb 09, 2016 12:37 am
just updated the library, grab a fresh copy and try!
https://github.com/adafruit/Adafruit_MQTT_Library
adafruit2
Site Admin
by thnikk on Tue Feb 09, 2016 12:49 am
That fixed it, thank you so much!
thnikk
