MQTT.fx
MQTT.fx
by RedBaron on Mon Feb 08, 2016 7:50 am
I'm a MQTT newbie. First I wanted to try some easy examples with my Windows PC. I found the MQTT.fx tutorial at adafruit. I followed these instructions https://learn.adafruit.com/desktop-mqtt-client-for-adafruit-io. I tried to connect to the server on several days at different times. I never got a connection. I checked my user data and the AIO key sevaral times too. I can't find a mistake. Can you give me a hint?
Kind regards RedBaron
This are my settings
MQTT.fx settings 1
MQTT.fx settings 2. As password is the same as i use to login to my dashboard
MQTT.fx settings 3
"Proxy" and "Last Will and Testament" are left blank
This is the log:
2016-02-08 12:36:56,508 INFO --- ScriptingManager : Found action with name: Switch Fountain Test
2016-02-08 12:38:33,930 INFO --- BrokerConnectorController : onConnect
2016-02-08 12:38:34,117 INFO --- MqttFX ClientModel : MqttClient with ID dbc55841fe.................7390f2fa5 assigned.
2016-02-08 12:38:34,630 ERROR --- MqttFX ClientModel : Error when connecting
org.eclipse.paho.client.mqttv3.MqttSecurityException: Not authorized to connect
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:28) ~[org.eclipse.paho.client.mqttv3-1.0.2.jar:?]
at org.eclipse.paho.client.mqttv3.internal.ClientState.notifyReceivedAck(ClientState.java:885) ~[org.eclipse.paho.client.mqttv3-1.0.2.jar:?]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:118) ~[org.eclipse.paho.client.mqttv3-1.0.2.jar:?]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_66]
2016-02-08 12:38:34,643 INFO --- ScriptsController : Clear console.
2016-02-08 12:38:34,644 ERROR --- BrokerConnectService : MqttSecurityException: Not authorized to connect
RedBaron
Re: MQTT.fx
by adafruit2 on Mon Feb 08, 2016 6:40 pm
your username password looks too short, it should be the same as your IO key!
https://learn.adafruit.com/desktop-mqtt ... onfiguring
adafruit2
Site Admin
Re: MQTT.fx
by RedBaron on Tue Feb 09, 2016 2:59 am
that solved the problem. thank you
RedBaron
