digital out sketch not behaving as expected
by paultravers on Tue Feb 09, 2016 5:55 am
I have been working through the digital out sketch in the adafruit mqtt library, using the blue led on the huzzah esp8266 to report the status of the GPIO#2 pin. Other than putting in my own wifi and adafruit.io details I haven't modified the sketch. While the sketch works in the sense that the board connects and receives either a "1" or a "0", the LED lights only momentarily. I had expected that it would light continuously while the lamp feed was set to "1", ie that on receiving a "1" pin 2 would be set to HIGH and that it would remain HIGH until a "0" was received. Have I misunderstood how it is supposed to work, or do I have a problem?
Paul
paultravers
Re: digital out sketch not behaving as expected
by adafruit2 on Tue Feb 09, 2016 4:01 pm
it should stay lit, but note that you have to set the pin LOW to keep the LED on
adafruit2
Site Admin
by paultravers on Thu Feb 11, 2016 7:06 am
I have tried manually setting the pin high or low, ie I added a line to the sketch
if (current == 1) digitalWrite(LAMP, HIGH);
I also tried setting it low .. and in neither case did the LED light other than momentarily .. I tried switching the pin to 12 and driving a piezo buzzer rather than a LED and all that does is click when receiving a "1". I tried a different ESP board and got the same result, just a momentary click on toggling the lamp feed.
I connected the buzzer to gnd and the 3v3 pin, and the buzzer does work.
The code I have now is
   if (subscription == &lamp) {
      // convert mqtt ascii payload to int
      char *value = (char *)lamp.lastread;
      Serial.print(F("Received: "));
      Serial.println(value);
      int current = atoi(value);
      Serial.print(current);Serial.print(">");
      // write the current state to the power switch tail
      digitalWrite(LAMP, current == 1 ? HIGH : LOW);
      Serial.println(current);
      if (current==1) {
        digitalWrite(LAMP,LOW);
        delay(500);
        digitalWrite(LAMP,HIGH);
        delay(500);
Any suggestions? At a bit of a loss here.
Paul
paultravers
by adafruit2 on Thu Feb 11, 2016 10:14 pm
sounds like you're getting data from IO, you just need to work out your project code...debugging and time will help you get it working!
adafruit2
Site Admin
