Adafruit IO Not Connect
by mikebrylinski on Thu Feb 11, 2016 10:01 pm
I built a 4 relay controller from a huzzah 8266, subscribing to 4 feeds from Adafruit IO. I had it working for a bit a few days ago, now it is having trouble connecting. Ive tried uploading the example "Digital Out" sketch, and it s still having this issue. Serial monitor just reads "connection failed" and keeps trying with no luck.
Screen Shot 2016-02-11 at 8.53.27 PM.png (187.38 KiB) Viewed 468 times
mikebrylinski
Re: Adafruit IO Not Connect
by adafruit2 on Sat Feb 13, 2016 3:53 pm
can you try the "mqtt_esp8266" example?
https://github.com/adafruit/Adafruit_MQTT_Library
adafruit2
Site Admin
by theskillster on Wed Feb 17, 2016 6:45 am
Hi There,
I'm also been struggling to connect my MQTT to Adafruit IO in the last couple of weeks.
I used the esp example above and still get connection failed:
Connection failed
Retrying MQTT connection in 5 seconds...
theskillster
