First Feed - Python
First Feed - Python
by txbobs on Sat Feb 13, 2016 12:59 am
I am playing around with my first feed and thought I would do a ping and log the date/time if the ping failed.
response=os.system("ping -c1 -w100 " + hostname2)
n = datetime.datetime.now()
if response == 0:
  print hostname2, 'is up.', n
else:
  print hostname2, 'is down!', n
  aio.send('Foo', n)
When I run this, n contains the date and time and prints ok but I get the following error when trying to send it. Any ideas would be appreciated.
pi@raspberrypi:~ $ python adaiotest.py
ping: unknown host texas.rr.com2
texas.rr.com2 is down! 2016-02-12 22:54:26.662560
File "adaiotest.py", line 20, in <module>
aio.send('Foo', n)
File "build/bdist.linux-armv6l/egg/Adafruit_IO/client.py", line 90, in send
File "build/bdist.linux-armv6l/egg/Adafruit_IO/client.py", line 71, in _post
File "/usr/lib/python2.7/json/__init__.py", line 243, in dumps
return _default_encoder.encode(obj)
File "/usr/lib/python2.7/json/encoder.py", line 207, in encode
chunks = self.iterencode(o, _one_shot=True)
File "/usr/lib/python2.7/json/encoder.py", line 270, in iterencode
return _iterencode(o, 0)
File "/usr/lib/python2.7/json/encoder.py", line 184, in default
raise TypeError(repr(o) + " is not JSON serializable")
TypeError: datetime.datetime(2016, 2, 12, 22, 54, 26, 662560) is not JSON serializable
txbobs
Re: First Feed - Python
by txbobs on Sat Feb 13, 2016 1:16 am
Well I don't understand why it was an error but If use str(), I can get it to work.
timestamp = str(n)
if response == 0:
else:
  aio.send('Foo', timestamp)
Thanks.
txbobs
