Feeds not updating
Feeds not updating
by black1990gsx on Mon Feb 15, 2016 4:07 am
Trying to do the adafruit io basics digital input
Using the basic digital in code
  Adafruit MQTT Library ESP8266 Example
  Must use ESP8266 Arduino from:
    https://github.com/esp8266/Arduino
  Works great with Adafruit's Huzzah ESP board:
  ----> https://www.adafruit.com/product/2471
  products from Adafruit!
  Written by Tony DiCola for Adafruit Industries.
  Adafruit IO example additions by Todd Treece.
  MIT license, all text above must be included in any redistribution
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
// function prototypes
void connect(void);
/****************************** Pins ******************************************/
#define BUTTON          2
/************************* WiFi Access Point *********************************/
#define WLAN_SSID       "...your SSID..."
#define WLAN_PASS       "...your password..."
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883
#define AIO_USERNAME    "...your AIO username (see https://accounts.adafruit.com)..."
#define AIO_KEY         "...your AIO key..."
/************ Global State (you don't need to change this!) ******************/
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
// Store the MQTT server, client ID, username, and password in flash memory.
// This is required for using the Adafruit MQTT library.
const char MQTT_SERVER[] PROGMEM    = AIO_SERVER;
// Set a unique MQTT client ID using the AIO key + the date and time the sketch
// was compiled (so this should be unique across multiple devices for a user,
// alternatively you can manually set this to a GUID or other random value).
const char MQTT_CLIENTID[] PROGMEM  = __TIME__ AIO_USERNAME;
const char MQTT_USERNAME[] PROGMEM  = AIO_USERNAME;
const char MQTT_PASSWORD[] PROGMEM  = AIO_KEY;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, MQTT_SERVER, AIO_SERVERPORT, MQTT_CLIENTID, MQTT_USERNAME, MQTT_PASSWORD);/****************************** Feeds ***************************************/
// Setup a feed called 'button' for publishing changes.
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
const char BUTTON_FEED[] PROGMEM = AIO_USERNAME "/feeds/button";
Adafruit_MQTT_Publish button = Adafruit_MQTT_Publish(&mqtt, BUTTON_FEED);
/*************************** Sketch Code ************************************/
// button state
int current = 0;
int last = -1;
  // set button pin as an input
  pinMode(BUTTON, INPUT_PULLUP);
  Serial.begin(115200);
  Serial.println(F("Adafruit IO Example"));
  // Connect to WiFi access point.
  Serial.println(); Serial.println();
  delay(10);
  Serial.print(F("Connecting to "));
  Serial.println(WLAN_SSID);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(F("."));
  Serial.println();
  Serial.println(F("WiFi connected"));
  Serial.println(F("IP address: "));
  Serial.println(WiFi.localIP());
  // connect to adafruit io
  connect();
  // ping adafruit io a few times to make sure we remain connected
  if(! mqtt.ping(3)) {
    // reconnect to adafruit io
    if(! mqtt.connected())
      connect();
  // grab the current state of the button
  current = digitalRead(BUTTON);
  // return if the value hasn't changed
  if(current == last)
    return;
  int32_t value = (current == LOW ? 1 : 0);
  // Now we can publish stuff!
  Serial.print(F("\nSending button value: "));
  Serial.print(value);
  Serial.print("... ");
  if (! button.publish(value))
    Serial.println(F("Failed."));
  else
    Serial.println(F("Success!"));
  // save the button state
  last = current;
// connect to adafruit io via MQTT
void connect() {
  Serial.print(F("Connecting to Adafruit IO... "));
  int8_t ret;
  while ((ret = mqtt.connect()) != 0) {
    switch (ret) {
      case 1: Serial.println(F("Wrong protocol")); break;
      case 2: Serial.println(F("ID rejected")); break;
      case 3: Serial.println(F("Server unavail")); break;
      case 4: Serial.println(F("Bad user/pass")); break;
      case 5: Serial.println(F("Not authed")); break;
      case 6: Serial.println(F("Failed to subscribe")); break;
      default: Serial.println(F("Connection failed")); break;
    if(ret >= 0)
      mqtt.disconnect();
    Serial.println(F("Retrying connection..."));
    delay(5000);
  Serial.println(F("Adafruit IO Connected!"));
The code seems to work as I get this in the serial debug
Sending button value: 1... Success!
Sending button value: 0... Success!
And yes I replaced all items I needed to for my AIO account, key and wi fi items as well as feed and so on..I have tried to recreate my dash board numerous times
I just want to see the Gage read 0 or 1 whe I press the button.
At a loss here
Thanks for help
black1990gsx
Re: Feeds not updating
by clemens on Mon Feb 15, 2016 9:49 am
What do you see on Adafruit IO? Do you see the automatically created feeds in the feed section?
clemens
by black1990gsx on Mon Feb 15, 2016 7:03 pm
I'm not sure what you mean by automatically created ones. I create the feed myself it it doesn't seem to change state
black1990gsx
by black1990gsx on Wed Feb 17, 2016 12:48 am
I went ahead and tried the actual MQTT esp8266 example.
I also turned on debug and got this
Connect result: 1
MQTT connect packet:
[0x10], Z [0x5A], [0x00], [0x06], M [0x4D], Q [0x51], I [0x49], s [0x73],
d [0x64], p [0x70], [0x03], Â [0xC2], [0x01], , [0x2C], [0x00], [0x14],
2 [0x32], 2 [0x32], : [0x3A], 4 [0x34], 2 [0x32], : [0x3A], 5 [0x35], 4 [0x34],
b [0x62], l [0x6C], a [0x61], c [0x63], k [0x6B], 1 [0x31], 9 [0x39], 9 [0x39],
0 [0x30], g [0x67], s [0x73], x [0x78], [0x00], [0x0C], b [0x62], l [0x6C],
a [0x61], c [0x63], k [0x6B], 1 [0x31], 9 [0x39], 9 [0x39], 0 [0x30], g [0x67],
s [0x73], x [0x78], [0x00], ( [0x28], e [0x65], 6 [0x36], 3 [0x33], 0 [0x30],
f [0x66], b [0x62], c [0x63], 5 [0x35], 4 [0x34], d [0x64], 0 [0x30], 9 [0x39],
c [0x63], 3 [0x33], 1 [0x31], f [0x66], e [0x65], e [0x65], 3 [0x33], d [0x64],
4 [0x34], 8 [0x38], e [0x65], 9 [0x39], 1 [0x31], 5 [0x35], 6 [0x36], 7 [0x37],
7 [0x37], 0 [0x30], 3 [0x33], a [0x61], 3 [0x33], a [0x61], e [0x65], 8 [0x38],
0 [0x30], a [0x61], a [0x61], 3 [0x33],
sendPacket returned: 92
Read packet: [0x20], [0x02], [0x00], [0x00],
MQTT subscription packet:
‚ [0x82], [0x1D], ­ [0xAD], ¯ [0xAF], [0x00], [0x18], b [0x62], l [0x6C],
s [0x73], x [0x78], / [0x2F], f [0x66], e [0x65], e [0x65], d [0x64], s [0x73],
/ [0x2F], o [0x6F], n [0x6E], o [0x6F], f [0x66], f [0x66], [0x00],
sendPacket returned: 31
Read packet: � [0x90], [0x03], ­ [0xAD], ¯ [0xAF], [0x00],
SUBACK: � [0x90], [0x03], ­ [0xAD], ¯ [0xAF], [0x00],
MQTT Connected!
Sending photocell val 0...MQTT publish packet:
0 [0x30], [0x1F], [0x00], [0x1C], b [0x62], l [0x6C], a [0x61], c [0x63],
k [0x6B], 1 [0x31], 9 [0x39], 9 [0x39], 0 [0x30], g [0x67], s [0x73], x [0x78],
/ [0x2F], f [0x66], e [0x65], e [0x65], d [0x64], s [0x73], / [0x2F], p [0x70],
h [0x68], o [0x6F], t [0x74], o [0x6F], c [0x63], e [0x65], l [0x6C], l [0x6C],
0 [0x30],
sendPacket returned: 33
OK!
Sending photocell val 1...MQTT publish packet:
1 [0x31],
OK!
My feed photocell still wont update.
really needing help with this one
I have even tried to wipe my feeds and dashboard starting with new AIO key
just looking for the next step to try
black1990gsx
by black1990gsx on Wed Feb 17, 2016 3:49 am
I am able to send data to the esp8266 from adafuit i/o just fine using the on/off example.
I still can't get data from esp8266 to the adafruit io broker.
Alos when I add another feed as a subscriber I get the following at it can;t even connect to adafruit io
Connecting to MQTT... Connecting to: io.adafruit.com
Connect result: 0
Connection failed
Retrying MQTT connection in 5 seconds...
Connect result: 1
0 [0x30], 1 [0x31], : [0x3A], 4 [0x34], 3 [0x33], : [0x3A], 2 [0x32], 6 [0x36],
‚ [0x82], [0x1E], ­ [0xAD], ¯ [0xAF], [0x00], [0x19], b [0x62], l [0x6C],
/ [0x2F], s [0x73], l [0x6C], i [0x69], d [0x64], e [0x65], r [0x72], [0x00],
sendPacket returned: 32
Read packet: 2 [0x32], [0x1E], [0x00], [0x18], b [0x62],
SUBACK: 2 [0x32], [0x1E], [0x00], [0x18], b [0x62],
Failed to subscribe
Connect result: 1
Connection failed
If I remove one of the subscriptions from the code it connect's fine
black1990gsx
by adafruit2 on Wed Feb 17, 2016 11:37 am
are you using the very latest adafruit_mqtt? we recently updated it
adafruit2
Site Admin
by black1990gsx on Wed Feb 17, 2016 7:29 pm
I'm using 11.1
thanks
black1990gsx
by black1990gsx on Wed Feb 17, 2016 7:48 pm
Just tried both 12.0 and 12.1
I can now get more than 1 sub working but still no go for publishing to a feed
black1990gsx
by pyremage on Sat Feb 20, 2016 10:52 am
I've said a while back that this is a problem for me as well, in the post viewtopic.php?f=56&t=89046 and it is still a problem today.
I am publishing the value of 4 different digital lines to gauge boxes, either a 0 or a 1, but they do not reflect the data. If I look at the feeds, they never change to show having received a 1 from an active line. The serial port is showing that AIO is acknowledging having received the data.
I need a more reliable way to keep the MCU and AIO synchronized, but until I work that out I need a simple indicator that they are not. I created feedback to show me this but AIO is not cooperating...as I said before, a simple lamp box would be great.
pyremage
