MQTT - Retained Messages
by Nikolai1024 on Mon Feb 15, 2016 11:41 am
Do you have any sample code or maybe you can provide and example of getting Retained Messages from MQTT. I would like to be able to get last feed values when I reset my feather or loose connection and reconnect.
Also, I'm using HTTP POST to submit my value to Aidafruit.io. Is there anything I need to set there?
Nick
Nikolai1024
Re: MQTT - Retained Messages
by adafruit2 on Tue Feb 16, 2016 10:02 pm
if you're doing REST you can always get the current message
the adafruit.io MQTT broker will, on connection, give you the retained message
Adafruit_MQTT will by default receive the retained message as the first one
*however* it only works for one feed right now - we have to add callback support to do more, no ETA - its in progress!
adafruit2
Site Admin
by Nikolai1024 on Tue Feb 16, 2016 10:56 pm
Great. I'll experiment with code to see if I can grab that value in MQTT. Looking forward to support for all feeds. Thanks.
Nikolai1024
