There may some shipping delays at this time, orders placed on Fri Jan 22, may not ship for 1-2 business days.
Unreliable connection
by krambriw on Sat Feb 20, 2016 10:52 am
I experience frequently that it is unreliable to connect. The Python script below verifies that several retries sometimes are needed to get a successful connection
Kind regards, Walter
from Adafruit_IO import MQTTClient
import time
def connected(client):
    client.subscribe(adafruitFeedId)
    print client.is_connected()
    global started
    global cntr
    started = True
    cntr = 0
def disconnected(client):
    del client
def message(client, feed_id, payload):
    msg = feed_id
    pl = payload
    print msg, pl
    client.disconnect()
def goConnect():
    # Create a MQTT client instance.
    client = MQTTClient(adafruitUser, adafruitIOkey)
    # Setup the callback functions defined above.
    client.on_connect    = connected
    client.on_disconnect = disconnected
    client.on_message    = message
    # Connect to the Adafruit IO server and start subscribing.
    client.connect()
    client.loop_background()
    return client
adafruitUser = 'user'
adafruitIOkey = 'iokey'
adafruitFeedId = 'mytest'
cntr = 0
started = False
while not started:
    client = goConnect()
    if cntr > 0:
        print 'Retry: ', cntr
    cntr += 1
    time.sleep(0.5)
krambriw
