Supporting Python 2.6
by krambriw on Sun Feb 21, 2016 3:48 am
Hi, since the library currently is written to support Python 2.7+ and 3.0+, I still needed this to work also with Python 2.6 ( In my particular case, Python 2.6.5 Stackless 3.1b3 060516 (release26-maint, Mar 20 2010, 15:26:51) [MSC v.1500 32 bit (Intel)] on win32 running in Win10 64 bit). I actually made this work by making a small code change in model.py:
# Define methods to convert from dicts to the data types.
def _from_dict(cls, data):
    # Convert dict to call to class initializer (to work with the data types
    # base on namedtuple).  However be very careful to preserve forwards
    # compatibility by ignoring any attributes in the dict which are unknown
    # by the data type.
    #params = {x: data.get(x, None) for x in cls._fields}
    #Modified to support Python 2.6 by krambriw 2015-02-19
    params = {}
    for x in cls._fields:
        params[x] = data.get(x, None)
    return cls(**params)
def _feed_from_dict(cls, data):
    params = {}
     # Parse the stream if provided and generate a stream instance.
    params['stream'] = Stream.from_dict(data.get('stream', {}))
def _group_from_dict(cls, data):
    params = {}
    # Parse the feeds if they're provided and generate feed instances.
    params['feeds'] = tuple(map(Feed.from_dict, data.get('feeds', [])))
Maybe the author could introduce a kind of switch that detects what version of Python is running and depending on this, select the appropriate way.
Kind regards
krambriw
