Can the feed accept decimals?
by kampto on Sun Feb 21, 2016 12:55 pm
I have set up a feed and it sends integers fine and they are fed. But Adafruit IO will not display decimals numbers.. Is this correct?
kampto
Re: Can the feed accept decimals?
by adafruit2 on Tue Feb 23, 2016 12:29 am
you can send any string, the library may have to format it into a string and that may require some noodling
adafruit2
Site Admin
by kosmonooit on Tue Feb 23, 2016 3:12 am
But what does the mqtt broker expect to see, and what gets displayed in the Ada IO feeds?
I had the same questions trying to get my feed to work, but could not find any specs in this regard.
kosmonooit
by adafruit2 on Tue Feb 23, 2016 10:57 am
it just sees a raw 'string' of data
adafruit2
Site Admin
by kampto on Tue Feb 23, 2016 11:11 am
Im using REST API method with Feather ESP8266 board and Arduino IDE. Why do I need a string to get a floated value to display in the AIO?
kampto
by adafruit2 on Tue Feb 23, 2016 11:56 am
not sure about REST but as for MQTT, the client sends a string, and then its up to the server to parse that out. if you graph the data, the string will be parsed for graphing
adafruit2
Site Admin
by kampto on Tue Feb 23, 2016 2:03 pm
But what does a string have to do with the AIO not displaying floated (decimal) values? So in conclusion the AIO can only display integers and not decimals? Which is not going to work if your monitoring LiPo battery voltage that range between 3 to 4 Volts.
kampto
by adafruit2 on Tue Feb 23, 2016 2:08 pm
not sure of what you're asking but you could always send the data in millivolts, then you range from ~2500 to 4300
adafruit2
Site Admin
by kampto on Tue Feb 23, 2016 2:45 pm
I can ask it in a more simple way. Can Adafruit IO dashboard plots display numbers with decimals, Yes or No?
My finding suggest No and you previous Answer suggests no as well.
kampto
by adafruit2 on Tue Feb 23, 2016 2:51 pm
not sure about the plots, but the *feed* should be able to store decimal. I'll ask the maintainer
adafruit2
Site Admin
by uniontownlabs on Tue Feb 23, 2016 2:56 pm
you should be able to graph any decimal values. see attached image:
uniontownlabs
by Karl33to on Fri Feb 26, 2016 6:37 pm
Kampto, the rest library has a bug with float values, if you look in the git issues there has been a fix posted which seems to work well.
https://github.com/adafruit/Adafruit_IO ... ll/2/files
Karl33to
