Is it just me?
Is it just me?
by krambriw on Mon Feb 29, 2016 1:22 pm
I think it started yesterday or the day before
I am being kicked in and out at an irregular interval. Sometimes the connection lasts only a minute or two, sometimes longer like 5-10 minutes. Since the library is reconnecting itself it seems, I just log when disconnected & connected events happen.
I subscribe to one of my two feeds but publish continuously two both well within the 5 minute limit
I just have feeling I did not experience disconnects that frequently last week
Kind regards,
Walter
krambriw
Re: Is it just me?
by jwcooper on Tue Mar 01, 2016 6:49 pm
We've made some more configuration changes to fix these disconnects. Are you still seeing this issue?
jwcooper
Re: Is it just me?
by krambriw on Wed Mar 02, 2016 12:48 am
Now it works excellent, no disconnects during at least last 6-8 hours
Thank You!
krambriw
Re: Is it just me?
by krambriw on Wed Mar 02, 2016 12:31 pm
Still working perfect! Not a single disconnect since you made your changes.
Best regards
krambriw
Re: Is it just me?
by jwcooper on Wed Mar 02, 2016 11:21 pm
Great news, thank you for the update!
jwcooper
Re: Is it just me?
by krambriw on Thu Mar 24, 2016 2:41 pm
Unfortunately it looks like the problem is back again. I am being kicked out approx every 5th minute even though I am publishing a message to a feed once every minute. Every fifth minute I receive the event 'disconnect'. I would say the problems started today at 12:42 pm my time (around 6:42 am New York) See my log below
Kind regards, Walter
2016-03-24 12:42:56   Event received: client.on_disconnect
2016-03-24 12:48:12   Event received: client.on_disconnect
2016-03-24 12:53:29   Event received: client.on_disconnect
2016-03-24 12:58:46   Event received: client.on_disconnect
2016-03-24 13:04:02   Event received: client.on_disconnect
2016-03-24 13:09:19   Event received: client.on_disconnect
2016-03-24 13:14:36   Event received: client.on_disconnect
2016-03-24 13:19:53   Event received: client.on_disconnect
2016-03-24 13:25:09   Event received: client.on_disconnect
2016-03-24 13:30:26   Event received: client.on_disconnect
2016-03-24 15:47:41   Event received: client.on_disconnect
2016-03-24 15:52:58   Event received: client.on_disconnect
2016-03-24 15:58:15   Event received: client.on_disconnect
2016-03-24 16:03:31   Event received: client.on_disconnect
2016-03-24 16:08:48   Event received: client.on_disconnect
2016-03-24 16:14:05   Event received: client.on_disconnect
2016-03-24 16:19:22   Event received: client.on_disconnect
2016-03-24 16:24:38   Event received: client.on_disconnect
2016-03-24 16:29:55   Event received: client.on_disconnect
2016-03-24 16:35:12   Event received: client.on_disconnect
2016-03-24 16:40:28   Event received: client.on_disconnect
2016-03-24 16:45:45   Event received: client.on_disconnect
2016-03-24 16:51:02   Event received: client.on_disconnect
2016-03-24 16:56:19   Event received: client.on_disconnect
2016-03-24 17:01:35   Event received: client.on_disconnect
2016-03-24 17:06:52   Event received: client.on_disconnect
2016-03-24 17:12:09   Event received: client.on_disconnect
2016-03-24 17:17:25   Event received: client.on_disconnect
2016-03-24 17:22:42   Event received: client.on_disconnect
2016-03-24 17:27:59   Event received: client.on_disconnect
2016-03-24 17:33:16   Event received: client.on_disconnect
2016-03-24 17:38:33   Event received: client.on_disconnect
2016-03-24 17:43:49   Event received: client.on_disconnect
2016-03-24 17:49:06   Event received: client.on_disconnect
2016-03-24 17:54:23   Event received: client.on_disconnect
2016-03-24 17:59:39   Event received: client.on_disconnect
2016-03-24 18:04:56   Event received: client.on_disconnect
2016-03-24 18:10:13   Event received: client.on_disconnect
2016-03-24 18:15:29   Event received: client.on_disconnect
2016-03-24 18:20:46   Event received: client.on_disconnect
2016-03-24 18:26:03   Event received: client.on_disconnect
2016-03-24 18:31:20   Event received: client.on_disconnect
2016-03-24 18:36:36   Event received: client.on_disconnect
2016-03-24 18:41:53   Event received: client.on_disconnect
2016-03-24 18:47:10   Event received: client.on_disconnect
2016-03-24 18:52:27   Event received: client.on_disconnect
2016-03-24 18:57:43   Event received: client.on_disconnect
2016-03-24 19:03:00   Event received: client.on_disconnect
2016-03-24 19:08:17   Event received: client.on_disconnect
2016-03-24 19:13:34   Event received: client.on_disconnect
2016-03-24 19:18:50   Event received: client.on_disconnect
2016-03-24 19:24:07   Event received: client.on_disconnect
2016-03-24 19:29:24   Event received: client.on_disconnect
krambriw
