Feed send failures
Feed send failures
by eehite on Mon Feb 29, 2016 8:02 pm
Evening all,
I have just started playing with the Adafruit REST libraries, and have so far been unable to get any operations to work.
#include <SPI.h>
#include <Ethernet2.h>
#include "Adafruit_IO_Client.h"
#define AIO_KEY  "...my key is here..."
byte mac[] = { 0x90, 0xA2, 0xDA, 0x10, 0x30, 0xD1 };
EthernetClient client;
Adafruit_IO_Client aio = Adafruit_IO_Client(client, AIO_KEY);
Adafruit_IO_Feed testFeed = aio.getFeed("test");
int value;
void setup()
  Serial.begin(9600);
  if (Ethernet.begin(mac) == 0)
    Serial.println(F("Ethernet Connection Failed"));
  Serial.println(Ethernet.localIP());
  aio.begin();
void loop()
  for (int i = 0; i < 100; i++)
    if (testFeed.send(value))
      Serial.println("sent value");
    else
      Serial.println("send failed");
Am I implementing this correctly? The code gets an IP just fine, but all I ever get is the send failure message and the feed is never modified.
I'm running this on an Uno with an Ethernet shield.
Thanks for any thoughts!
eehite
Re: Feed send failures
by adafruit2 on Mon Feb 29, 2016 10:16 pm
try adafruit_mqtt and the Ethernet example
https://github.com/adafruit/Adafruit_MQ ... hernet.ino
adafruit2
Site Admin
by play2liv on Sat Mar 05, 2016 10:42 pm
Hi what kind of project are you working on? What kind of data are you trying see on IO.adafruit? Did you ever get it to work?
play2liv
