Reactive Trigger Use Case
by pthacker on Thu Mar 03, 2016 12:24 am
I want to turn "on" a toggle button if another feed is 1 or higher. Should I set the feed for the toggle to ON or 1 or ...
Sorry this is the first trigger I've tried to create.
Thanks in advance.
pthacker
Re: Reactive Trigger Use Case
by jwcooper on Fri Mar 04, 2016 11:40 am
Set it to 1, but make sure that in your sketch you turn it back to 0, or it will continue triggering as the triggers are currently built. We'll change the triggers in the future to be a bit more intelligent about that though. You could also try ifttt.com as we're connected with them using realtime push as well.
jwcooper
