Python library - a question & maybe a request
by krambriw on Tue Apr 05, 2016 3:30 am
I am running the python Adafruit MQTT Client as a sub-process in a Python framework. For what ever reason, users sometimes like to stop the Adafruit MQTT Client but since there is no method to stop the background thread started by the call to loop_background() it continues running. To terminate it, I have to end the whole framework.
Would it be possible to modify the library so that it also includes a stop method (is actually already supported by paho)??? Eventually you could consider to add a call to client.loop_stop() internally when calling client.disconnect() but that might break some other fellows implementations
As example:
client.loop_background()
client.loop_stop()
As a work-around I have defined a separate thread in my code that instead uses client.loop() but it would be nicer to use the foreseen client.loop_background()
Kind regards, Walter
krambriw
Re: Python library - a question & maybe a request
by krambriw on Tue Apr 05, 2016 4:22 am
Just additional info. I made a temporary fix and added the following to your mqtt_client.py and it seems to work fine
    def loop_stop(self):
        """Stops a background thread from listen for messages from Adafruit.IO
        self._client.loop_stop()
krambriw
