Increment Trigger
Increment Trigger
by customuser on Tue Apr 05, 2016 7:37 pm
I'd like to be able to use a momentary button feed to increment a gauge feed. An example use would be setting the target temperature that could then be polled from the gauge feed.
Screen Shot 2016-04-05 at 7.35.52 PM.png (27.33 KiB) Viewed 259 times
The current trigger system only allows a feed to set a specific value. (AFAIK)
customuser
Re: Increment Trigger
by jwcooper on Wed Apr 06, 2016 5:11 pm
I like this idea. We can add it as an option when creating the momentary button. For now, you'd need to use the text block, and manually enter the value, or use a slider. We're in the middle of revamping our UI, so this may take a bit of time to get to.
jwcooper
by customuser on Thu Apr 07, 2016 11:08 am
While we're on the subject, AND, and OR would be helpful.
If block one is greater than x AND block two is less than y, do z.
customuser
by Mr_Paul on Thu Apr 07, 2016 2:41 pm
On the flip side, you could probably do these things with very very few lines of python (just subscribe to the buttons and publish to the gauge), though it would have to be running all the time, and might be slightly laggy (though IO seems very snappy)
What you really want IO to support is lamda, ala AWS, where you could upload a chunk of code triggered by anything....that would be cool, and easier then hosting your own version (which is basically what I am suggesting).
Mr_Paul
