M0 Feather with WINC1500 and IoT!
Re: M0 Feather with WINC1500 and IoT!
Adafruit IO winc1500 test!
Attempting to connect to Marso_Wi-Fi...Attempting to connect to SSID: Marso_Wi-Fi
Connected!
Ready!
Error writing value to feed!
Waiting 10 seconds and then reading the feed value.
Received value from feed:
Waiting 10 seconds and then writing a new feed value.
#include <Adafruit_WINC1500.h>
#include <SPI.h>
// #include "utility/debug.h"
#include "Adafruit_IO_WINC1500.h"
// Configure WiFi access point details.
#define WLAN_SSID "Marso_Wi-Fi" // can't be longer than 32 characters!
#define WLAN_PASS "my_pass"
// Configure Adafruit IO access.
#define AIO_KEY "my_AIO_key"
// #include "my_keys.h"
// Configure WINC1500 pins.
// guide you don't need to modify these:
#define WINC_CS 8
#define WINC_IRQ 7
#define WINC_RST 4
// #define WINC_EN 2 // or, tie EN to VCC and comment this out
// The SPI pins of the WINC1500 (SCK, MOSI, MISO) should be
// connected to the hardware SPI port of the Arduino.
// On an Uno or compatible these are SCK = #13, MISO = #12, MOSI = #11.
// On an Arduino Zero use the 6-pin ICSP header, see:
// https://www.arduino.cc/en/Reference/SPI
// Setup the WINC1500 connection with the pins above and the default hardware SPI.
Adafruit_WINC1500 WiFi(WINC_CS, WINC_IRQ, WINC_RST);
// Create an Adafruit IO Client instance. Notice that this needs to take a
// WINC1500 object as the first parameter, and as the second parameter a
// default Adafruit IO key to use when accessing feeds (however each feed can
// override this default key value if required, see further below).
Adafruit_IO_WINC1500 aio = Adafruit_IO_WINC1500(WiFi, AIO_KEY );
// Finally create instances of Adafruit_IO_Feed objects, one per feed. Do this
// by calling the getFeed function on the Adafruit_IO_WINC1500 object and passing
// it at least the name of the feed, and optionally a specific AIO key to use
// when accessing the feed (the default is to use the key set on the
// Adafruit_IO_Client class).
Adafruit_IO_Feed testFeed = aio.getFeed("my_username/feeds/my_feed");
// Global state to increment a number and send it to the feed.
unsigned int count = 0;
#define halt(s) { while(true) { Serial.println(F( s )); delay(1000); } }
// Setup serial port access.
Serial.begin(9600);
Serial.println(F("Adafruit IO winc1500 test!"));
// Attempt to connect to an access point.
Serial.print(F("\nAttempting to connect to "));
Serial.print(WLAN_SSID); Serial.print(F("..."));
// attempt to connect to Wifi network:
while (WiFi.status() != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(WLAN_SSID);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
WiFi.begin(WLAN_SSID, WLAN_PASS);
// wait 10 seconds for connection:
uint8_t timeout = 10;
while (timeout && (WiFi.status() != WL_CONNECTED)) {
timeout--;
delay(1000);
Serial.println(F("Connected!"));
// Initialize the Adafruit IO client class (not strictly necessary with the
// client class, but good practice).
aio.begin();
Serial.println(F("Ready!"));
// Increment the count value and write it to the feed.
count += 1;
// To write a value just call the feed's send function and pass it the value.
// Send will create the feed on Adafruit IO if it doesn't already exist and
// then add the value to it. Send returns a boolean that's true if it works
// and false if it fails for some reason.
if (testFeed.send(count)) {
Serial.print(F("Wrote value to feed: ")); Serial.println(count, DEC);
else {
Serial.println(F("Error writing value to feed!"));
// Now wait 10 seconds and read the current feed value.
Serial.println(F("Waiting 10 seconds and then reading the feed value."));
Serial.flush(); // if no console hangs
delay(10000);
// To read the latest feed value call the receive function on the feed.
// The returned object will be a FeedData instance and you can check if it's
// valid (i.e. was successfully read) by calling isValid(), and then get the
// value either as a text value, or converted to an int, float, etc.
FeedData latest = testFeed.receive();
if (latest.isValid()) {
Serial.print(F("Received value from feed: ")); Serial.println(latest);
// By default the received feed data item has a string value, however you
// can use the following functions to attempt to convert it to a numeric
// value like an int or float. Each function returns a boolean that indicates
// if the conversion succeeded, and takes as a parameter by reference the
// output value.
int i;
if (latest.intValue(&i)) {
Serial.print(F("Value as an int: ")); Serial.println(i, DEC);
// Other functions that you can use include:
// latest.uintValue() (unsigned int)
// latest.longValue() (long)
// latest.ulongValue() (unsigned long)
// latest.floatValue() (float)
// latest.doubleValue() (double)
else {
Serial.print(F("Failed to receive the latest feed value!"));
// Now wait 10 more seconds and repeat.
Serial.println(F("Waiting 10 seconds and then writing a new feed value."));
Serial.flush();
delay(10000);
Connected!
Ready!
HTTP POST failed with error code: 302
Failed to connect to service!
