Warning for failure with > 3 subscriptions on adafruit IO!
by erikwed on Sun May 01, 2016 8:11 am
Hey everybody,
I'm using the Adafruit HUZZAH connecting to Adafruit IO. I am experiencing total failure to connect to Adafruit IO when I try subscribing to more than three subscriptions, even though the limit according to the MQTT_library is 5 and changeable.
Is this something that everybody knows except me or is it a problem worth investigating?
Thank you for your thoughts.
Regards Erik
erikwed
Re: Warning for failure with > 3 subscriptions on adafruit
by cbmalloch on Wed May 04, 2016 10:39 am
I too am using Huzzah, and have been successful connecting 5 subscriptions. However, I wanted to connect 8 subscriptions, and accordingly changed MAX_SUBSCRIPTIONS to 10. That was fine, but when I added the code for the next subscription (number 6) it would subscribe to the first 5 and then fail to connect beyond that.
I hope we can figure this out!
I actually wanted to use the MQTT wildcard (<me>/feeds/blah/*) to have one topic "blah" with subtopics "0" through "7", but that seems to be unsupported.
cbmalloch
by erikwed on Thu May 12, 2016 11:23 am
yes, something is obviously wrong regarding subscription amount limit... Hopefully someone can help us out here.
erikwed
