MKR1000 and Adafruit MQTT Library
by pilow on Sun May 01, 2016 4:06 pm
I was struggling with "error: 'dtostrf' was not declared in this scope" when compiling sketches for Arduino MKR1000 when including Adafruit_MQTT_Library
As per the doc, this library is not compatible with all hardware.
The missing function (dtostrf) id declared in Adafruit_MQTT.cpp lines 24 to 31
#ifdef ARDUINO_SAMD_ZERO
static char *dtostrf (double val, signed char width, unsigned char prec, char *sout) {
  char fmt[20];
  sprintf(fmt, "%%%d.%df", width, prec);
  sprintf(sout, fmt, val);
  return sout;
#endif
just duplicate this code block in the cpp file, and change to :
#ifdef ARDUINO_SAMD_MKR1000
  char fmt[20];
  return sout;
#endif
So that you keep compatibility with Arduino Zero, and get an error free compilation for Arduino MKR1000 board !
"C:\Users\xxx\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -x assembler-with-cpp -DF_CPU=48000000L -DARDUINO=10608 -DARDUINO_SAMD_MKR1000 -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804e -DUSBCON '-DUSB_MANUFACTURER="Arduino LLC"' '-DUSB_PRODUCT="Arduino MKR1000"' "-IC:\Users\xxx\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel/CMSIS/Include/" "-IC:\Users\xxx\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel/Device/ATMEL/" "-IC:\Users\xxx\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.5\cores\arduino" "-IC:\Users\xxx\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.5\variants\mkr1000" "C:\Users\xxx\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.5\cores\arduino\pulse_asm.S" -o "C:\Users\xxx\AppData\Local\Temp\buildfa67b9090c78c4dce955f3b5a8052adf.tmp\core\pulse_asm.S.o"
You can find the file to modify in the \Documents\Arduino\libraries\Adafruit_MQTT folder.
Been logging Luminosity and Temperature flawlessly with Adafruit MQTT Library to Adafruit.IO since this little hack with my MKR1000 ! =)
pilow
cron
