error compiling remote_monitoring program for iot starter ki
by jnunes on Tue May 03, 2016 1:18 pm
Arduino: 1.6.8 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, 40MHz, QIO, 115200, 4M (3M SPIFFS), nodemcu, Disabled, None"
WARNING: library AzureIoT claims to run on [samd] architecture(s) and may be incompatible with your current board which runs on [esp8266] architecture(s).
In file included from C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/common/include/nm_common.h:45:0,
                 from C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/driver/include/m2m_wifi.h:49,
                 from C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:28,
                 from C:\Users\Student\Documents\AzureIoT-master\examples\esp8266\remote_monitoring\remote_monitoring.ino:1:
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/bsp/include/nm_bsp.h:110:23: error: conflicting declaration 'typedef long unsigned int uint32'
 typedef unsigned long uint32;
In file included from C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\cores\esp8266/esp8266_peri.h:24:0,
                 from C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\cores\esp8266/Arduino.h:38,
                 from sketch\remote_monitoring.ino.cpp:1:
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0/tools/sdk/include/c_types.h:29:29: error: 'uint32' has a previous declaration as 'typedef unsigned int uint32'
 typedef unsigned int        uint32;
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/bsp/include/nm_bsp.h:133:22: error: conflicting declaration 'typedef long int sint32'
 typedef signed long  sint32;
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0/tools/sdk/include/c_types.h:32:29: error: 'sint32' has a previous declaration as 'typedef int sint32'
 typedef signed int          sint32;
In file included from C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:28:0,
                 from C:\Users\Student\Documents\AzureIoT-master\examples\esp8266\remote_monitoring\remote_monitoring.ino:13:
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/include/wl_definitions.h:51:27: error: redeclaration of 'WL_NO_SHIELD'
     WL_NO_SHIELD        = 255,   // for compatibility with WiFi Shield library
In file included from C:\Users\Student\Documents\AzureIoT-master\examples\esp8266\remote_monitoring\remote_monitoring.ino:1:0:
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:37:2: note: previous declaration 'wl_status_t WL_NO_SHIELD'
  WL_NO_SHIELD = 255,
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/include/wl_definitions.h:52:27: error: redeclaration of 'WL_IDLE_STATUS'
     WL_IDLE_STATUS      = 0,
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:38:2: note: previous declaration 'wl_status_t WL_IDLE_STATUS'
  WL_IDLE_STATUS = 0,
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/include/wl_definitions.h:53:27: error: redeclaration of 'WL_NO_SSID_AVAIL'
     WL_NO_SSID_AVAIL    = 1,
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:39:2: note: previous declaration 'wl_status_t WL_NO_SSID_AVAIL'
  WL_NO_SSID_AVAIL,
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/include/wl_definitions.h:54:27: error: redeclaration of 'WL_SCAN_COMPLETED'
     WL_SCAN_COMPLETED   = 2,
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:40:2: note: previous declaration 'wl_status_t WL_SCAN_COMPLETED'
  WL_SCAN_COMPLETED,
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/include/wl_definitions.h:55:27: error: redeclaration of 'WL_CONNECTED'
     WL_CONNECTED        = 3,
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:41:2: note: previous declaration 'wl_status_t WL_CONNECTED'
  WL_CONNECTED,
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/include/wl_definitions.h:56:27: error: redeclaration of 'WL_CONNECT_FAILED'
     WL_CONNECT_FAILED   = 4,
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:42:2: note: previous declaration 'wl_status_t WL_CONNECT_FAILED'
  WL_CONNECT_FAILED,
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/include/wl_definitions.h:57:27: error: redeclaration of 'WL_CONNECTION_LOST'
     WL_CONNECTION_LOST  = 5,
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:43:2: note: previous declaration 'wl_status_t WL_CONNECTION_LOST'
  WL_CONNECTION_LOST,
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/include/wl_definitions.h:58:27: error: redeclaration of 'WL_DISCONNECTED'
     WL_DISCONNECTED     = 6
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:44:2: note: previous declaration 'wl_status_t WL_DISCONNECTED'
  WL_DISCONNECTED
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/include/wl_definitions.h:59:3: error: conflicting declaration 'typedef enum wl_status_t wl_status_t'
 } wl_status_t;
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:45:3: error: 'wl_status_t' has a previous declaration as 'typedef enum wl_status_t wl_status_t'
 } wl_status_t;
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/include/wl_definitions.h:62:6: error: multiple definition of 'enum wl_enc_type'
 enum wl_enc_type {  /* Values map to 802.11 encryption suites... */
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:48:6: error: previous definition here
In file included from C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiClient.h:36:7: error: redefinition of 'class WiFiClient'
 class WiFiClient : public Client, public SList<WiFiClient> {
In file included from C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:32:0,
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFiClient.h:28:7: error: previous definition of 'class WiFiClient'
 class WiFiClient : public Client {
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiClient.h:119:15: error: prototype for 'size_t WiFiClient::write(T&, size_t)' does not match any in class 'WiFiClient'
 inline size_t WiFiClient::write(T& source, size_t unitSize) {
In file included from C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\cores\esp8266/Stream.h:26:0,
                 from C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\cores\esp8266/HardwareSerial.h:31,
                 from C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\cores\esp8266/Arduino.h:246,
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\cores\esp8266/Print.h:56:16: error: candidates are: size_t Print::write(const char*)
         size_t write(const char *str) {
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\cores\esp8266/Print.h:62:16: error:                 size_t Print::write(const char*, size_t)
         size_t write(const char *buffer, size_t size) {
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFiClient.h:42:17: error:                 virtual size_t WiFiClient::write(const uint8_t*, size_t)
  virtual size_t write(const uint8_t *buf, size_t size);
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFiClient.h:41:17: error:                 virtual size_t WiFiClient::write(uint8_t)
  virtual size_t write(uint8_t);
In file included from C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:40:0,
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiServer.h:37:7: error: redefinition of 'class WiFiServer'
 class WiFiServer : public Server {
In file included from C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:34:0,
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFiServer.h:28:7: error: previous definition of 'class WiFiServer'
In file included from C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:41:0,
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiClientSecure.h:34:3: error: 'WiFiClientSecure::~WiFiClientSecure()' marked override, but does not override
   ~WiFiClientSecure() override;
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiClientSecure.h:49:10: error: 'size_t WiFiClientSecure::peekBytes(uint8_t*, size_t)' marked override, but does not override
   size_t peekBytes(uint8_t *buffer, size_t length) override;
In file included from C:\Users\Student\Documents\AzureIoT-master\examples\esp8266\remote_monitoring\remote_monitoring.ino:13:0:
C:\Users\Student\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:86:25: error: conflicting declaration 'ESP8266WiFiClass WiFi'
 extern ESP8266WiFiClass WiFi;
C:\Users\Student\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:150:18: error: 'WiFi' has a previous declaration as 'WiFiClass WiFi'
 extern WiFiClass WiFi;
exit status 1
Error compiling for board Generic ESP8266 Module.
jnunes
Re: error compiling remote_monitoring program for iot starte
by adafruit_support_rick on Thu May 05, 2016 10:20 am
Please don't double post. You other thread is here
viewtopic.php?f=53&t=95753&p=480521#p480521
