CC3000 Digital In Sketch Help - Adding Delay to DS18S20 Temp
by moyerek on Tue May 10, 2016 11:11 pm
Apologize for such a simply question but haven't been able to figure out where I should place delay so I am only reading my sensor less often. I really only need to record the temperature every 10 minutes. I am using the "Adafruit CC3000 Digital In" example sketch that I modified to work with a DS18S20 temp sensor. Everything is running fine except every time I insert a delay somewhere it never connects to Wifi.
I didn't include the top of the sketch defining all the set-ups, etc. The below sketch works fine but again, no delay.
Any help would be most appreciated.
/*************************** Sketch Code ************************************/
//Temperature chip i/o
OneWire ds(DS18S20_Pin);  // on digital pin 2
  Serial.begin(115200);
  Serial.println(F("Adafruit IO Example:"));
  Serial.print(F("Free RAM: ")); Serial.println(getFreeRam(), DEC);
  // Initialise the CC3000 module
  Serial.print(F("\nInit the CC3000..."));
  if (! cc3000.begin())
    halt("Failed");
  // attempt wifi connection
  while (! CC3000connect(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
    Serial.println(F("Retrying WiFi"));
    while(1);
  Serial.println(F("Connected to WiFi!"));
  // connect to adafruit io
  connect();
  // Make sure to reset watchdog every loop iteration!
  Watchdog.reset();
  float tempC = getTemp();
  float tempF = (tempC * 9.0)/ 5.0 + 32.0;
if(tempF < 60)
return;
  // ping adafruit io a few times to make sure we remain connected
  if(! mqtt.ping(3)) {
    // reconnect to adafruit io
    if(! mqtt.connected())
      connect();
  // Now we can publish stuff!
  Serial.print(F("\nSending temp value: "));
  Serial.print(tempF);
  Serial.print("... ");
  if (! temp.publish(tempF))
    Serial.println(F("Failed."));
  else
    Serial.println(F("Success!"));
// connect to adafruit io via MQTT
void connect() {
  Serial.print(F("Connecting to Adafruit IO... "));
  int8_t ret;
  while ((ret = mqtt.connect()) != 0) {
    switch (ret) {
      case 1: Serial.println(F("Wrong protocol")); break;
      case 2: Serial.println(F("ID rejected")); break;
      case 3: Serial.println(F("Server unavail")); break;
      case 4: Serial.println(F("Bad user/pass")); break;
      case 5: Serial.println(F("Not authed")); break;
      case 6: Serial.println(F("Failed to subscribe")); break;
      default:
        Serial.println(F("Connection failed"));
        CC3000connect(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
        break;
    if(ret >= 0)
      mqtt.disconnect();
    Serial.println(F("Retrying connection..."));
    delay(5000);
  Serial.println(F("Adafruit IO Connected!"));
float getTemp(){
  //returns the temperature from one DS18S20 in DEG Celsius
  byte data[12];
  byte addr[8];
  if ( !ds.search(addr)) {
      //no more sensors on chain, reset search
      ds.reset_search();
      return -1000;
  if ( OneWire::crc8( addr, 7) != addr[7]) {
      Serial.println("CRC is not valid!");
      return -1000;
  if ( addr[0] != 0x10 && addr[0] != 0x28) {
      Serial.print("Device is not recognized");
      return -1000;
  ds.reset();
  ds.select(addr);
  ds.write(0x44,1); // start conversion, with parasite power on at the end
  byte present = ds.reset();
  ds.select(addr);
  ds.write(0xBE); // Read Scratchpad
  for (int i = 0; i < 9; i++) { // we need 9 bytes
    data[i] = ds.read();
  ds.reset_search();
  byte MSB = data[1];
  byte LSB = data[0];
  float tempRead = ((MSB << 8) | LSB); //using two's compliment
  float TemperatureSum = tempRead / 16;
  return TemperatureSum;
moyerek
Re: CC3000 Digital In Sketch Help - Adding Delay to DS18S20
by adafruit_support_rick on Thu May 12, 2016 9:28 am
Just did the very same thing last night (except with an ESP8266). I put the delay here, and it worked just fine:
  else
  delay(60000);
That's not working for you?
by moyerek on Thu May 12, 2016 9:50 pm
Thanks for the help.
moyerek
