IO Graphs Y-axis flicks between “0" and "Y-axis Minimum”
by davidau on Sat May 14, 2016 8:26 pm
I am monitoring voltages of a solar array and battery and often set the “Y-axis minimum” value so I can see in more detail what the charging circuit is doing to the voltage.
Looking at it this week with the Y-axis minimum set greater than 0 I see the graph’s Y axis flicks between “0" and "Y-axis Minimum”. I have 3 separate graphs and it does this on all three.
davidau
