"C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Bill\AppData\Local\Temp\arduino_build_426243/arduino.ar" "C:\Users\Bill\AppData\Local\Temp\arduino_build_426243\core\cont_util.c.o"
C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar: unable to rename 'C:\Users\Bill\AppData\Local\Temp\arduino_build_426243/arduino.ar'; reason: File exists
My first feather compile - I understand the error but not what caused it.
Any suggestions ?
Unable to rename -
- wdickenson
Re: Unable to rename -
Tried deleting it manually and got the same message. It's got me stymied. Thanks
- danhalbert
There may be some issue with the esp8266 package; I did some searching and found others with this problem. Try uninstalling Arduino, deleting the C:\Users\Bill\AppData\Local\Arduino15 folder, and cleaning up any leftover arduino stuff in C:\Users\Bill\AppData\Local\Temp. Then install the latest version of Arduino and the ESP8266 support package. But it may be some kind of issue with the ESP8266 support:
https://github.com/esp8266/Arduino/issues/2987
https://github.com/esp8266/Arduino/issues/3926
https://arduino.stackexchange.com/quest ... tion-error
- wdickenson
Thank you - I am on my way home so I will try tomorrow.
Thanks again
Thanks again
- wdickenson
It took a bit longer (lots of sketches) but it's working ! Thank you
- wdickenson
I am going to reopen this .....
When i reinstalled, the test feather worked fine. I thought the issue solved.
Later that day, I tried to run the Alexa (Echo) code from Adafruit and the file error popped up. So I went back and forth. Looks like the 3 libraries necessary for the Feather are not working as designed. I added a program to wipe the directory but that surely cannot be the right answer.
So I'm back for guidance !
