Feather and Raspberry Pi over WiFi
by Tbot1000 on Wed Jul 11, 2018 5:56 pm
Hello, I am working on a project that takes sensor data on a Feather M0 WiFi, and sends it to a Raspberry Pi Zero and displays it on a web page. Posting information is simple enough on the Feather, because I work with Arduino a lot, but I am not sure how to either read the data off the web page using an RPi or transmit information directly. Thank You for any help.
Tbot1000
Re: Feather and Raspberry Pi over WiFi
by adafruit_support_mike on Sat Jul 14, 2018 3:01 am
The easiest way to handle that is to have the webserver provide the information the microcontroller wants as a textfile.
Either write the data to a file explicitly, and give it a name like 'feather-data.txt' or write CGI code that uses 'Content-type: text/plain' to generate output. Either way, you get a URL the Feather can load that will return just the data you need, with little extraneous formatting to wade through.
by Tbot1000 on Wed Jul 18, 2018 12:26 pm
Also, can I hook up a Thunder Click https://www.mikroe.com/thunder-click to the feather using SPI? Also, How would that be wired? It runs on an AS3935 chip. If not, are there any other lightning breakout boards?
Tbot1000
