Feather M4 Express SERCOM
by Ddahl08 on Fri Jun 14, 2019 7:12 pm
Can someone please post an example of a working SERCOM for the M4 feather. It seems that following the "Using ATSAMD21 SERCOM for more SPI, I2C and Serial ports" in the Learn section does not work with the M4.
I would like Serial2 on the SDA and SCL pins.
SCL pin 22 - RX - sercom2.1
SDA pin 21 - TX - sercom2.0
Ddahl08
Re: Feather M4 Express SERCOM
by timdriedger on Fri Jun 28, 2019 2:55 pm
Did you ever figure this out?
I'm also wanting to add additional serial ports to my Feather M4 for a project.
timdriedger
by timdriedger on Fri Jun 28, 2019 3:43 pm
I found a combination that worked for Sercom 0...
#include <Arduino.h>
#include "wiring_private.h"
Uart Serial2 (&sercom0, A5, A4, SERCOM_RX_PAD_2, UART_TX_PAD_0);
void SERCOM0_0_Handler() {
  Serial2.IrqHandler();
void SERCOM0_1_Handler() {
void SERCOM0_2_Handler() {
void SERCOM0_3_Handler() {
  Serial.begin(115200);
  Serial2.begin(115200);
  pinPeripheral(A5, PIO_SERCOM_ALT);
  pinPeripheral(A4, PIO_SERCOM_ALT);
uint8_t i = 0;
  Serial.print(i);
  Serial2.write(i++);
  if (Serial2.available()) {
    Serial.print(" -> 0x"); Serial.print(Serial2.read(), HEX);
  Serial.println();
  delay(10);
timdriedger
by timdriedger on Fri Jun 28, 2019 3:48 pm
And another for Sercom 4...
Uart Serial2 (&sercom4, A3, A2, SERCOM_RX_PAD_1, UART_TX_PAD_0);
void SERCOM4_0_Handler() {
void SERCOM4_1_Handler() {
void SERCOM4_2_Handler() {
void SERCOM4_3_Handler() {
  pinPeripheral(A3, PIO_SERCOM_ALT);
  pinPeripheral(A2, PIO_SERCOM_ALT);
uint8_t i = 0;
  Serial.print(i);
  Serial2.write(i++);
  Serial.println();
  delay(10);
timdriedger
cron
