Trying to read voltage from photoresitor
by apurcell666 on Thu Dec 19, 2019 1:50 pm
Im using an esp32 and am trying to read the voltage from a photoresistor. If I connect to A0 I get the below output
<Serial>
3507
3507
3505
3503
3503
3504
3501
3504
3505
3505
3507
3503
3519
3503
3505
3509
3503
</Serial>
No matter what I do to the photoresistor the values never change or actually match the voltage as read with a multi-meter. If I change the analog pin and update the code it always reads zero from any other pin. Any ideas? What am I doing wrong?
int protocell = 0;
int read_v = 0;
  // put your setup code here, to run once:
Serial.begin(115200);
  // put your main code here, to run repeatedly:
read_v = analogRead(protocell);
Serial.println(read_v);
delay(300);
apurcell666
Re: Trying to read voltage from photoresitor
by jps2000 on Thu Dec 19, 2019 2:00 pm
A photoresitor change its resistance with light. It does not output a voltage. So you need another resistor to make a voltage divider.
for example take a resistor ( value 10k ....100k) from A0 to GND and the photoresistor from A0 to VCC (3V3)
Then light lowers the resistor and voltage on A0 gets higher
jps2000
by apurcell666 on Thu Dec 19, 2019 2:18 pm
I know you need voltage divider. That is what I am referring to by trying read voltage. Matter of fact I followed the example given here: https://learn.adafruit.com/photocells/circuitpython I am thinking the board is toast. Used the same circuit and code on a Arduino and it worked fine.
apurcell666
by adafruit_support_mike on Fri Dec 20, 2019 2:27 am
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
by marktaylr on Tue Jan 14, 2020 11:32 am
Maybe too late for original poster, but in case it helps someone else:
The problem is in the code. Attempting to read A0 by passing a 0 into the Read function. There is always a layer (or two) of redirection between ESP32 internal logical name, pinouts, Arduino logical names, Feather pinouts, ...
From the Feather docs
A0 - this is an analog input A0 and also an analog output DAC2. It can also be used as a GPIO #26. It uses ADC #2
A1 - this is an analog input A1 and also an analog output DAC1. It can also be used as a GPIO #25. It uses ADC #2
A2 - this is an analog input A2 and also GPI #34. Note it is not an output-capable pin! It uses ADC #1
A3 - this is an analog input A3 and also GPI #39. Note it is not an output-capable pin! It uses ADC #1
A4 - this is an analog input A4 and also GPI #36. Note it is not an output-capable pin! It uses ADC #1
A5 - this is an analog input A5 and also GPIO #4. It uses ADC #2
A0 is GPIO 26. Using Arduino code to read the analog value needs 26 as a function argument:
analogRead(26);
marktaylr
