Logics does not work
by hangstrom on Thu Sep 03, 2020 10:11 am
Logics does not work with my Adafruit Feather M0 Adalogger
msTime = millis();
if (msTime > 2000) {
this line executes normally msTime is a unsigned long
msTime = millis();
if ((msTime > 2000) && (BolY)) {
this line never executes although the bool BolY is true
The same software works normal with Arduino Due
The developer is Arduino 1.8.13
My aim is also to use the Wire software
hangstrom
Re: Logics does not work
by hypercubed on Fri Sep 04, 2020 2:07 pm
Could you post full code?
What do you want it to do?
hypercubed
by hangstrom on Wed Sep 16, 2020 5:36 am
The logics on row 40-41 does not work.
I can get it work by shortening the switch-statement.
The purpose is to serial communicate with a display
  FeatherErr
 HEÅ 200916
#include <SPI.h>
#define KeyPIN A5
#define VBATPIN A7
#define analog3 A3
#define PPin A2
#define TrigPin 13
#define CSB 5
#define RS 6
#define ResDisp 10
#define RW 11
int KeyVal = 0, KeyVal1 = 0, NoLoop, InitDispStep = 0;
float PVal, an3, Vbat,OutT;
char LastKey, KeyRes;
bool DispNotReady = true, DspChk;
long msTime, KeyDelT = 300, KeyRdStep = 50, KeyTime;
unsigned long LastKeyRdT = 0, InitDispT = 0;
// the setup function runs once when you press reset or power the board
  pinMode(TrigPin, INPUT_PULLUP); // Start log signal
  pinMode(8, OUTPUT);
  pinMode(TrigPin, OUTPUT);
  pinMode(CSB, OUTPUT);
  digitalWrite(CSB, LOW); //chip select low
  pinMode(RS, OUTPUT);
  digitalWrite(RS, LOW); //RS low
  pinMode(ResDisp, OUTPUT);
  digitalWrite(ResDisp, LOW); //Reset LOW, do reset
  pinMode(RW, OUTPUT);
  digitalWrite(RW, LOW); //R/W low
  Serial.begin(9600);
  SPI.begin();
// the loop function runs over and over again forever
  msTime = millis();
  DspChk = (bool) (msTime > 2000) && DispNotReady;
  if (DspChk){
    //Serial.println(msTime);
    InitDisp();
void InitDisp(){
  Serial.println("Start Init display");
  Serial.println((msTime - InitDispT));
  if ((msTime - InitDispT)>=2){
    InitDispT = msTime;
    Serial.print("InitDispStep = ");
    Serial.println(InitDispStep);
    switch (InitDispStep){
      case 0:
        //digitalWrite(ResDisp, HIGH); //Reset high
        break;
      case 1:
        //SPI.transfer(byte(0x31));// 8 bit, 1 line, instr. table 1
        break;
      case 2:
        //SPI.transfer(byte(0x14));//BS 1/5, 1 line
        break;
      case 3:
        //SPI.transfer(byte(0x55));//booster on, contrast C5, set C4
        break;
      case 4:
        //SPI.transfer(byte(0x6D));//set voltage follower and gain1
        break;
      case 5:
        //SPI.transfer(byte(0x7C));//set contrast C3, C2, C1
        break;
      case 6:
        //SPI.transfer(byte(0x30));//switch back to instruction table 0
        break;
      case 7:
        //SPI.transfer(byte(0x0F));//display on, cursor on, cursor blink
        break;
      case 8:
       //SPI.transfer(byte(0x01));//delete display, cursor at home
        break;
      case 9:
        //SPI.transfer(byte(0x06));//cursor auto-increment
        Serial.println("Inited display");
        DispNotReady = false;
        break;
    InitDispStep += 1;
FeatherErr.ino
(2.47 KiB) Downloaded 1 time
Last edited by adafruit_support_bill on Wed Sep 16, 2020 5:51 am, edited 1 time in total.
Reason: added code in-line
hangstrom
