Adafruit Feather nRF52840 - Quadrature decoder
by MKCreatin1 on Mon Nov 16, 2020 9:41 am
Is it possible, using Arduino IDE, to access the nrf52480's quadrature decoder module when using the Adafruit Feather nRF52840?
I'm interested in speed feedback, using the nrf52840s hardware, from a motors quadrature encoder.
Many thanks,
Matt
MKCreatin1
Re: Adafruit Feather nRF52840 - Quadrature decoder
by dastels on Mon Nov 16, 2020 12:09 pm
Short answer: yes, you're working in C++ and can do anything supported by the hardware.
Longer answer: Some research is warranted and as a last resort you could find the relevant material in section 6.18 of the nRF52840 tech manual https://infocenter.nordicsemi.com/pdf/nRF52840_PS_v1.1.pdf. It looks like there is some work done that would at least be a place to start: https://github.com/adafruit/Adafruit_nRF52_Arduino/tree/master/libraries/RotaryEncoder
dastels
by MKCreatin1 on Sat Nov 21, 2020 5:40 pm
Thanks dastels! I've begun looking down this rabbit hole.
One question that I'm stuck on at the moment is that I can't seem to compile a program that references a nrf52840 register. I have picked a random register within the qdec called "IRK".
Can anyone tell me why it won't compile?
Thanks for your time!
#include <Arduino.h>
#include <bluefruit.h>
IRK |= B00100000;
MKCreatin1
by dastels on Sat Nov 21, 2020 6:36 pm
You'll need a header for the MCU, i.e. the nRF52840. Hmm.. maybe start digging in the Arduino hardware support. On my machine that's at ~/.arduino15/packages/adafruit/hardware/nrf52/
Or maybe the rotario support in CircuitPython: https://github.com/adafruit/circuitpython/tree/main/ports/nrf/common-hal/rotaryio.
dastels
