Music Maker FeatherWing not playing music
Re: Music Maker FeatherWing not playing music
by Hotshot7997 on Wed Apr 21, 2021 3:37 pm
So just to make sure right now we are focusing just on the switch ont he block correct? Did we confirm the no sound as being an issue? Asking because like i said if I use another music maker I can hear sound
Hotshot7997
by adafruit_support_carter on Wed Apr 21, 2021 3:51 pm
Correct. Just trying to figure out what caused this behavior:
Block doesnt work at all and if you use the switch it causes the whole setup to glitch and the feather hangs.
which doesn't seem related to the Wing. So idea is to just run a simple blink test and then see if you can recreate the hang up.
by Hotshot7997 on Wed Apr 21, 2021 4:35 pm
I'll check the voltage to see if I am getting power to the block when using the blink script
Hotshot7997
by Hotshot7997 on Thu Apr 22, 2021 4:00 am
OK with everything mounted and blinky running I am not able to get a voltage from the block. I checked USB to ground and 3.3v to ground nothing gives me a read out.
Hotshot7997
by adafruit_support_carter on Thu Apr 22, 2021 11:30 am
You are making these measurements directly on the Terminal Block FeatherWing? Where exactly? The screw terminals? The header pins? Somewhere on the prototype area?
by Hotshot7997 on Thu Apr 22, 2021 11:00 pm
I have tried several points along the path. I get voltage on the header pins of the feather but nothing at an point on the block.
Hotshot7997
by adafruit_support_carter on Fri Apr 23, 2021 3:38 pm
So it's like the Feather pins are not connecting down into the terminal block Wing?
by Hotshot7997 on Mon Apr 26, 2021 4:00 am
it seems like it but they are seated to the max. I cannot insert them any further.
Hotshot7997
by adafruit_support_carter on Mon Apr 26, 2021 10:49 am
That's very odd. If I'm understanding where these measurements are being made. Assuming your soldering is OK, then it seems internal to the DuPont connectors.
by Hotshot7997 on Mon Apr 26, 2021 1:11 pm
Yeah the soldering is fine. I tried to even reflow just in case and no changes.
Hotshot7997
by adafruit_support_carter on Mon Apr 26, 2021 1:14 pm
Total mystery. At this point it seems like you can not even get continuity between two connected header pins.
by Hotshot7997 on Mon Apr 26, 2021 1:41 pm
Let me know whats next. It seems the feather is ok but music maker is not and the block isnt either. I mean with the feather the other issue i faced is the spare music maker Ihad the right channel now has a buzzing it didnt have prior to introducing it tot he mix. So not sure if the feather might be the root cause to this. really thought this would be plug-n-play not plug-n-pray lol
Hotshot7997
by Hotshot7997 on Tue Apr 27, 2021 2:46 pm
So do we try to RMA the Music maker and the block for now and test with the feather?
Hotshot7997
by Hotshot7997 on Wed Apr 28, 2021 2:40 pm
let me know I have a client waiting over a month for this project. Thank you :-)
Hotshot7997
by adafruit_support_carter on Wed Apr 28, 2021 4:07 pm
Try switching to a continuity check instead of voltage check. Remove the Music Maker Wing. Have just the Feather mounted on the Terminal block. Remove all power and any other connections. Go pin by pin between the Feather header pins and the corresponding pins the Terminal block. Do they all fail continuity? Only some? If, so which ones?
