Feather Fona - SIM Module doesn't stay off
by bauerbyter on Sat May 15, 2021 2:38 am
Hey,
I have an Adafruit Feather Fona with an TPL51111. The Feather is turning on every 2 Hours with the enable pin. At the end of my sketch I use:
    digitalWrite(keyPin, HIGH);
    delay(500);
    digitalWrite(keyPin, LOW);
    delay(2000);
to turn off the SIM Module. This is working, but afterwards I set the DonePin of the TPL51111 to HIGH and the Feather shuts down... and unfortunately the SIM Module turns on again after 1-2 seconds (TPL and Feather are staying off). Does somebody know how to fix this?
Edit: some more informations: keyPin is pin 12 and is connected to the KeyPin. And yes I cutted the "key-pad".
bauerbyter
Re: Feather Fona - SIM Module doesn't stay off
by adafruit_support_mike on Sat May 15, 2021 10:01 pm
Set the KEY pin high again after the FONA shuts off.
by bauerbyter on Sun May 16, 2021 2:41 am
Hey thanks for your answer, but how should I do that, when everything is off ?
It feels like there is a short peak when the device is turning off and this is treated like HIGH. But I have no idea how to pull the key high after the Fona shuts down.
bauerbyter
by adafruit_support_mike on Sun May 16, 2021 7:25 pm
Even on the Feather FONA, the microcontroller should keep running when the SIM800 module is shut down.
by bauerbyter on Mon May 17, 2021 6:28 am
Ah understood you wrong.
So at the End just Key Pin to High and when the microcontroller is disabled, it will be set to GND.
Unfortunately, still doesnt work perfectly. It goes off but after 20-30seconds it starts again, without changing anything.
bauerbyter
by adafruit_support_mike on Mon May 17, 2021 6:19 pm
If you're also shutting down the microcontroller, you'll need to connect a pull-up resistor to the KEY pin to keep its voltage high when everything else is shut off.
by bauerbyter on Tue May 18, 2021 3:48 am
Done that also (with 5k resistor), doesnt work. -.-
bauerbyter
by adafruit_support_mike on Tue May 18, 2021 5:30 pm
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
