In 2019 I bought a pair of Feather M0 Basic Proto boards. I found the upload almost impossible and all attempts to use the boards failed. I moved on the teensy 3.2 - works like a charm.
I tried again this month on a new Windows 10 machine with a high speed Intel I9-10850K CPU @ 3.60GHz processor and the latest Arduino IDE version 1.8.15.
From power on I just uploaded the blink example code using the 'upload' button (next to the checkmark):
1st click - compiles and locks up for more than 2 minutes - case 1
2nd click - compiles and get the upload error message - case 2
3rd click - compiles and shows the 'disk' contents in windows explorer then the machine beeps a few times and the upload goes through - case 3 (ok result) These beeps are the sound of Windows closing and opening virtual com port from USB devices.
4th click - works - twice in a row this time
5th click - locks
6th click - error in upload
7th click - works
8th click - locks
9th click - error in upload
10th click - works
as Bob Newhart would have said 'that is really going to cut our time to the coast' (Phone call to the Wright brothers. circa mid 1960s https://www.youtube.com/watch?v=7Azg6ohQlV0 3 minutes audio only as funny today as it was then)
also Windows opens a Com4 port then closes it and use the original Com3 port
to get rid of unused com ports on windows open the device manager and in the view menu select show hidden devices - right click the grey device and uninstall it
Double click (with just the right touch) of the reset button does open the 'disk' and shows the 'current.uf2' file and two others one of which is a url to adafruit
both boards do the same thing
If there is a fix for this let me know. But at least someone with my same problem can use this as a workaround. Even on this machine the compiler isn't that swift and compiling the code 3 times per upload is a real bummer.
best you you in NYC from California -Bob
feather M0 basic proto upload experience on windows
- bob_belleville
- adafruit_support_carter
Re: feather M0 basic proto upload experience on windows
Trying doing this first:
Does it seem to behave better that way?
That puts the board in bootloader mode. The folder should be something with BOOT in the name. But you can ignore the folder for Arduino use. There should also be a COM port that shows up. So you can select that COM port in the Arduino IDE and upload as normal. The board will accept the sketch upload in bootloader mode.Double click (with just the right touch) of the reset button does open the 'disk' and shows the 'current.uf2' file and two others one of which is a url to adafruit
- bob_belleville
thanks for your note
this solution is a 'well sort of'
double click reset and get the boot loader and a new com port - in my case com 3 goes to com 4
enter tools menu and switch the port from com 3 to com 4
upload button - works
the Arduino app has switched back to com 3
use the upload button again and it locks up as before - twice more to get the upload complete
my applications usually involves moving the board to a box that cannot be opened with out disturbing the experiment in progress - so I can't double click in general
in another experiment:
clicking the upload button once stops the running program and the red led is on - press upload button and the three clicks and you are in works as before - so no win
these feathers are going back in the bag to wait for some application that can tolerate this behavior
The COM port switching is a feature of Windows, unfortunately.
It sounds like putting the board into bootloader mode, and making sure COM port matches, results in reliable upload?
And just to be sure - if you don't put the board in bootloader mode, but do double check the COM port before upload, that still results in the mixed success behavior?
- bob_belleville
- adafruit2
turn on verbose upload and compile in arduino prefs
try and 'fail' to upload
then paste the output here *USING THE CODE BLOCK BUTTON ABOVE* so we can read it :)
- bob_belleville
The lockup case: (the lines 'PORTS {COM6, } / {COM6, } => {}' come rather slowely say 4 per second)
after sereral minutes the line 'An error occurred while uploading the sketch' show up after the stuff above
------------------------------------ the error case --------------------------------------------------------------------------
----------------------------------------------------- the correct upload case -----------------------------------------------------
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Bob\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Bob\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Bob\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_feather_m0:opt=small,usbstack=arduino,debug=off -vid-pid=239A_800B -ide-version=10815 -build-path C:\Users\Bob\AppData\Local\Temp\arduino_build_110908 -warnings=none -build-cache C:\Users\Bob\AppData\Local\Temp\arduino_cache_218971 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS-Atmel\1.2.2 -prefs=runtime.tools.CMSIS-Atmel-1.2.2.path=C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS-Atmel\1.2.2 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.bossac.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.arm-none-eabi-gcc-9-2019q4.path=C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.CMSIS.path=C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.CMSIS-5.4.0.path=C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.openocd.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Bob\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Bob\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Bob\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_feather_m0:opt=small,usbstack=arduino,debug=off -vid-pid=239A_800B -ide-version=10815 -build-path C:\Users\Bob\AppData\Local\Temp\arduino_build_110908 -warnings=none -build-cache C:\Users\Bob\AppData\Local\Temp\arduino_cache_218971 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS-Atmel\1.2.2 -prefs=runtime.tools.CMSIS-Atmel-1.2.2.path=C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS-Atmel\1.2.2 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.bossac.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.arm-none-eabi-gcc-9-2019q4.path=C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.CMSIS.path=C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.CMSIS-5.4.0.path=C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.openocd.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'adafruit_feather_m0' from platform in folder: C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.2
Using core 'arduino' from platform in folder: C:\Users\Bob\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.2
Detecting libraries used...
"C:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_FEATHER_M0 -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x800B -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather M0\"" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2/libraries/Adafruit_TinyUSB_Arduino/src/arduino" -Os -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_FEATHER_M0 -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x800B -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather M0\"" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2/libraries/Adafruit_TinyUSB_Arduino/src/arduino" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS-Atmel\\1.2.2/CMSIS/Device/ATMEL/" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2\\cores\\arduino" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2\\variants\\feather_m0" "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908\\sketch\\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_FEATHER_M0 -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x800B -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather M0\"" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2/libraries/Adafruit_TinyUSB_Arduino/src/arduino" -Os -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_FEATHER_M0 -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x800B -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather M0\"" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2/libraries/Adafruit_TinyUSB_Arduino/src/arduino" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS-Atmel\\1.2.2/CMSIS/Device/ATMEL/" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2\\cores\\arduino" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2\\variants\\feather_m0" "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_FEATHER_M0 -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x800B -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather M0\"" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2/libraries/Adafruit_TinyUSB_Arduino/src/arduino" -Os -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_FEATHER_M0 -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x800B -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather M0\"" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2/libraries/Adafruit_TinyUSB_Arduino/src/arduino" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS-Atmel\\1.2.2/CMSIS/Device/ATMEL/" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2\\cores\\arduino" "-IC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2\\variants\\feather_m0" "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: C:\Users\Bob\AppData\Local\Temp\arduino_build_110908\core\variant.cpp.o
Using precompiled core: C:\Users\Bob\AppData\Local\Temp\arduino_cache_218971\core\core_bdaa7a8713c67cec116347dfd48b750f.a
Linking everything together...
"C:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" "-LC:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2\\variants\\feather_m0/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908/Blink.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908/Blink.ino.elf" "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908\\sketch\\Blink.ino.cpp.o" "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math "-LC:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.2\\variants\\feather_m0" -lm "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908/..\\arduino_cache_218971\\core\\core_bdaa7a8713c67cec116347dfd48b750f.a" -Wl,--end-group
"C:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908/Blink.ino.elf" "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908/Blink.ino.bin"
"C:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908/Blink.ino.elf" "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908/Blink.ino.hex"
"C:\\Users\\Bob\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-size" -A "C:\\Users\\Bob\\AppData\\Local\\Temp\\arduino_build_110908/Blink.ino.elf"
Sketch uses 10664 bytes (4%) of program storage space. Maximum is 262144 bytes.
Forcing reset using 1200bps open/close on port COM6
Uploading using selected port: COM6
C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3/bossac.exe -i -d --port=COM6 -U true -i -e -w -v C:\Users\Bob\AppData\Local\Temp\arduino_build_110908/Blink.ino.bin -R
Arduino: 1.8.15 (Windows 10), TD: 1.54-beta9, Board: "Adafruit Feather M0, Small (-Os) (standard), Arduino, Off"
Compiling sketch...
Compiling core...
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:152)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2071)
at java.lang.Thread.run(Thread.java:748)
Caused by: processing.app.SerialException: Error touching serial port 'COM6'.
at processing.app.Serial.touchForCDCReset(Serial.java:107)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:136)
... 5 more
Caused by: jssc.SerialPortException: Port name - COM6; Method name - openPort(); Exception type - Port busy.
at jssc.SerialPort.openPort(SerialPort.java:164)
at processing.app.Serial.touchForCDCReset(Serial.java:101)
... 6 more
Exception in thread "Thread-24" java.util.ConcurrentModificationException
at java.util.LinkedList$LLSpliterator.forEachRemaining(LinkedList.java:1239)
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481)
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471)
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:151)
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:174)
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:418)
at cc.arduino.contributions.libraries.LibrariesIndexer.rescanLibraries(LibrariesIndexer.java:169)
at processing.app.BaseNoGui.onBoardOrPortChange(BaseNoGui.java:719)
at processing.app.Base.onBoardOrPortChange(Base.java:1345)
at processing.app.Editor$UploadHandler.run(Editor.java:2107)
Compiling sketch...
Compiling core...
PORTS {COM6, } / {} => {}
PORTS {} / {COM7, } => {COM7, }
Found upload port: COM7
C:\Users\Bob\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3/bossac.exe -i -d --port=COM7 -U true -i -e -w -v C:\Users\Bob\AppData\Local\Temp\arduino_build_110908/Blink.ino.bin -R
Set binary mode
readWord(addr=0)=0x20002dd8
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v1.1 [Arduino:XYZ] May 12 2018 18:17:10
chipId=0x10010005
Connected at 921600 baud
Atmel SMART device 0x10010005 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v1.1 [Arduino:XYZ] May 12 2018 18:17:10
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security : false
Boot Flash : true
readWord(addr=0x40000834)=0x7000a
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 0.801 seconds
Write 10920 bytes to flash (171 pages)
write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x1000)
[=========== ] 37% (64/171 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x3000, size=0x1000)
[====================== ] 74% (128/171 pages)write(addr=0x20005000,size=0xac0)
writeBuffer(scr_addr=0x20005000, dst_addr=0x4000, size=0xac0)
[==============================] 100% (171/171 pages)
done in 0.170 seconds
Verify 10920 bytes of flash with checksum.
checksumBuffer(start_addr=0x2000, size=0x1000) = df3
checksumBuffer(start_addr=0x3000, size=0x1000) = d7e1
checksumBuffer(start_addr=0x4000, size=0xaa8) = 554
Verify successful
done in 0.012 seconds
CPU reset.
writeWord(addr=0xe000ed0c,value=0x5fa0004)
