Huzzah32 Power Question
by BuffaloFan32 on Wed Jul 21, 2021 1:25 pm
The guide for the Huzzah32 says that using the 5V/USB pin to power it could damage your computer if it is powered up and you inadvertently connect the USB cord. Does the same risk exist if I transform the voltage from my power supply to 3.3V and use that pin?
BuffaloFan32
Re: Huzzah32 Power Question
by mikeysklar on Thu Jul 22, 2021 5:45 pm
Are you saying you would like to pull the EN pin to GND to disable the 3v regulator and then power the Huzzah32 off the 3v or BAT pin? I think that would be fine and not have the same backpower risk as 5v on the USB pin.
mikeysklar
by BuffaloFan32 on Sat Jul 24, 2021 1:32 am
Yes, I think that was what I was saying. Thank you!
BuffaloFan32
