5V Power to Huzzah32 Not Working
by BuffaloFan32 on Sat Jul 31, 2021 8:57 pm
Wiring
ESP32 wiring.jpg (102.46 KiB) Viewed 56 times
I used this tutorial to make an LED blink on my new Huzzah32:
https://makeabilitylab.github.io/physcomp/esp32/led-blink.html
Everything worked great so I decided to take it one step further and replace the USD connection with one of these (connected to a 5V switching power supply):
https://www.adafruit.com/product/3972
Not only did the LED stop blinking but smoke started coming out of the Huzzah32. Any idea what I am doing wrong?
BuffaloFan32
Re: 5V Power to Huzzah32 Not Working
by dastels on Sat Jul 31, 2021 11:08 pm
I suspect it was your power wiring.
Double check it all. Triple check it. Then check it again. Before you plug anything in.
Alas, if you saw smoke, I doubt the board is functional now. I suppose there's a chance it still works... but smoke is a pretty bad sign.
dastels
by BuffaloFan32 on Sat Jul 31, 2021 11:11 pm
Fortunately, the board still works when I plug it into my computer. I tried the same setup with a 5v wall wart, again nothing. Then I tried the 5v micro USB wall wart that I use to power my Raspberry Pi and it worked. Any ideas?
BuffaloFan32
by dastels on Sat Jul 31, 2021 11:27 pm
How is the first wall wart wired to the circuit? I assume the Pi one is plugged directly into the feather?
dastels
by BuffaloFan32 on Sun Aug 01, 2021 12:10 am
I have a barrel jack connector. The + goes to the + strip on the breadboard, the - goes to the - (similar to the picture above). Then the + is connected to E and the - is connected to A on the micro USB converter in the picture above.
BuffaloFan32
by dastels on Sun Aug 01, 2021 11:04 am
That's correct. Is anything else connected to the Feather's power pins (directly or indirectly)?
dastels
by BuffaloFan32 on Sun Aug 01, 2021 11:13 am
Nope
BuffaloFan32
