Feather RP2040 + HC-SR04 Ultrasonic Sonar Distance Sensor
by imhavoc on Sat Mar 27, 2021 11:26 pm
using the sample code from https://learn.adafruit.com/ultrasonic-s ... ce-sensors, I get the following results:
code.py output:
0.272
0.272
0.272
0.272
0.272
0.272
0.272
0.272
0.272
0.272
0.272
0.272
  File "code.py", line 11, in <module>
  File "code.py", line 9, in <module>
  File "adafruit_hcsr04.py", line 144, in distance
  File "adafruit_hcsr04.py", line 159, in _dist_two_wire
AttributeError: 'HCSR04' object has no attribute '_timeout'
I loaded the code on a Isty Bitsy M0, and it works great.
I moved back to the Feather, and moved the echo pin, and got the exact same result.
imhavoc
Re: Feather RP2040 + HC-SR04 Ultrasonic Sonar Distance Senso
by imhavoc on Mon Mar 29, 2021 11:40 am
Hooked up a neopixel ring, no problems. Looks like something in the HCSR04 library is not playing nice with the RP2040.
imhavoc
by imhavoc on Mon Mar 29, 2021 11:05 pm
Downloaded the latest libraries: adafruit-circuitpython-bundle-6.x-mpy-20210329
Still failing. It takes longer to fail, but it still fails.
imhavoc
by adafruit_support_carter on Tue Mar 30, 2021 12:40 pm
Which Feather RP2040 pins are you using for trigger and echo?
by imhavoc on Tue Mar 30, 2021 12:58 pm
adafruit_support_carter wrote:Which Feather RP2040 pins are you using for trigger and echo?
Pin D5 for trigger,
Pin D6 for echo.
(It occurred to me last night that the Pin 5 on the Itsy Bisy is 5V, which may explain why it's working and the Feather is not. (?))
imhavoc
by adafruit_support_carter on Tue Mar 30, 2021 1:16 pm
While the Trig signal can be 3V or 5V, the 'return' Echo signal is 5V logic. For that reason, we include two 10K resistors, use these as a divider to convert the 5V logic level to a safe 2.5V that you can ready with your 3V device.
Are you setting up the voltage divider?
by imhavoc on Tue Mar 30, 2021 2:04 pm
adafruit_support_carter wrote:Are you setting up the voltage divider?
Yes.
imhavoc
by adafruit_support_carter on Tue Mar 30, 2021 2:26 pm
Hmm. I think I'm seeing the same thing. It might be RP2040 related. There' still some issues being worked out for it. Want to open a new issue here?
https://github.com/adafruit/Adafruit_Ci ... R04/issues
by imhavoc on Tue Mar 30, 2021 2:57 pm
here is a diagram:
Screenshot 2021-03-30 125412.png (155.51 KiB) Viewed 75 times
imhavoc
by stocksp on Fri Aug 20, 2021 3:44 pm
I'm have exactly the same results.
New Feather hardware (running the sample app with a voltage divider on the Echo) ... I get a dozen good reads and then the crash.
"AttributeError: 'HCSR04' object has no attribute '_timeout'"
Which doesn't make any sense (to me!) as the _timeout attribute does exist.
I moved the library source into my code and printed out the value on each loop (0.1)
Reading the discussion above I'm hearing this is a problem with the Feather and NOT the RP2040?
Did I understand correctly? as I see so many examples of the HCSR04 running on the 'naked' Pico.
Don't mind moving off the Feather till this is resolved ... IF this is a Feather problem and not also a RP2040 or CircuitPython issue...
thanks for any guidance!
P:)
stocksp
by stocksp on Mon Aug 23, 2021 12:51 am
I updated my CircuitPython from 6 to 7.0 alpha 6 and the Ultrasonic sensor works perfectly!!
oh happy days!
P:)
stocksp
by imhavoc on Thu Sep 23, 2021 10:15 am
stocksp wrote:I updated my CircuitPython from 6 to 7.0 alpha 6 and the Ultrasonic sensor works perfectly!!
oh happy days!
P:)
stocksp, good to know! Thanks for the info.
imhavoc
