Huzzah32 IO Current Limits?
by Exonerd on Fri Sep 24, 2021 12:10 am
Greetings! I'm trying to assess using a Huzzah32 Feather for driving a small motor. I haven't been able to find the current limits of the PWM - compatible pins posted anywhere (or for the ESP32 in general). Help would be appreciated!
Exonerd
Re: Huzzah32 IO Current Limits?
by TI545 on Mon Sep 27, 2021 9:58 am
I did not see the current limits for the PWM in any obvious place either, but the power (amps) to drive the servo motor will come from the 5 volt connection to the motor. The PWM pin is only a low amp square wave, so it should work. Just make sure your 5 volt supply is strong enough for the size motor you select.
TI545
by Exonerd on Wed Oct 06, 2021 2:05 am
True, but those 5V USB grade inputs can support upwards of an amp, which I HIGHLY doubt even the whole board could tolerate as output. I'm assuming less than 50 mA per pin to be safe and don't want to experiment too much with it.
Exonerd
