Bluefruit nRF52 dual_bleuart - Identifying data source
twonius
Post by twonius »
I've got the dual_bleuart example working but i'm not able to differentiate which bytes are coming from which device.
Looking at the rx callback and the BLEClientUART wrapper I don't see how this information is available.
void cent_bleuart_rx_callback(BLEClientUart& cent_uart)
  char str[20+1] = { 0 };
  cent_uart.read(str, 20);
  Serial.print("[Cent] RX: ");
  Serial.println(str);
  if ( bleuart.notifyEnabled() )
    // Forward data from our peripheral to Mobile
    bleuart.print( str );
  }else
    // response with no prph message
    clientUart.println("[Cent] Peripheral role not connected");
I'm also only seeing output from one of the devices however if I only connect to one at a time I will see data for either (they're both flashed with the same code)
22:46:58.968 -> [Cent] RX: 246622
mikeysklar
Re: Bluefruit nRF52 dual_bleuart - Identifying data source
Post by mikeysklar »
@twonius,
Would it make sense to modify the code between the two nodes to be slightly different as to identify them self with each RX string?
eg.
Serial.print("[Cent] RX NODE1: ");
Serial.print("[Cent] RX NODE2: ");
twonius
Post by twonius »
wouldn't i need a different rx callback for each node?
Also it'd be unlikely that the peripherals would connect in the same order, so each time you'd have a different device using a different callback.
I really need to be able to do something like pull the UUID for the device so i can append it to the readings
I wonder if this just wouldn't be an issue if i would use one of the normal profiles instead of UART e.g. weight scale
mikeysklar
@twonius,
Maybe something like this scanner chunk of code would help to determine the UUID of each of your peripherals.
if ( Bluefruit.Scanner.checkReportForUuid(report, CUSTOM_SERVICE) )
    Serial.printf("%14s %s\n", "CUSTOM_SERVICE", "UUID Found!");
viewtopic.php?f=57&t=144086&p=711347&hi ... id#p711347
twonius
Post by twonius »
Looking at other examples the central_bleuart_multi example gets pretty close to what I want.
Honestly i could probably make this work and just flash my devices with individual names but it'd be nice to be able to use their UUIDs instead.
I just need to find out where this struct is defined so i can see which field is the UUID.
void bleuart_rx_callback(BLEClientUart& uart_svc)
  // uart_svc is prphs[conn_handle].bleuart
  uint16_t conn_handle = uart_svc.connHandle();
  int id = findConnHandle(conn_handle);
  prph_info_t* peer = &prphs[id];
  // Print sender's name
  Serial.printf("[From %s]: ", peer->name);
  // Read then forward to all peripherals
  while ( uart_svc.available() )
    // default MTU with an extra byte for string terminator
    char buf[20+1] = { 0 };
    if ( uart_svc.read(buf,sizeof(buf)-1) )
      Serial.println(buf);
      sendAll(buf);
mikeysklar
You must have found this by now, but just to confirm.
// Struct containing peripheral info
typedef struct
  char name[16+1];
  uint16_t conn_handle;
  // Each prph need its own bleuart client service
  BLEClientUart bleuart;
} prph_info_t;
prph_info_t is defined at the top of central_bleuart_multi.ino that you had been using.
twonius
Post by twonius »
that groaning sound was not a disturbance in the force.
