issues with feather RP2040 and AHT20
by ltheoret on Tue Oct 12, 2021 10:07 pm
I was wondering if there was an issue with the Adafruit_AHTX0 library and the Feather PR2040.
The Feather PR2040 using the STEMMA connector freezes every time I try to initialize the AHT20.
I tried the same AHT20 on the Metro M4 using the STEMMA to 4-Pin cable and it works great.
Is this an issue with Arduino IDE not yet supported for the Feather RP2040?
Luc
ltheoret
Re: issues with feather RP2040 and AHT20
by adafruit_support_carter on Wed Oct 13, 2021 5:50 pm
The STEMMA connector on the Feather RP2040 ends up being Wire1 instead of Wire. So change your call to begin() to be like:
aht.begin(&Wire1)
by ltheoret on Wed Oct 13, 2021 10:01 pm
Thank you. Did not see that. Thanks again. :)
Luc
ltheoret
