It's ­čÉŹCircuitPython Monday­čÉŹ at Adafruit! Use the code ADATY to get 20% off CircuitPython and 15% off items storewide!
Feather M0 RFM95 upload sketch while in low power sleep
by michaelstranks on Sat Oct 16, 2021 11:52 am
I have a M0 with the RFM95 and I am using it as a field unit for collecting and sending data. I am using LowPower.sleep() to save power between transmissions, but when it is in low power mode, I cannot access it via the com port (Windows 10) it doesn't even show up in the list. Currently, the way it's set up, I have to leave the batter plugged in, so I can't technically even power it down. Is there some way I can factory reset it while still on battery power so that I can find it in the COM ports and upload a new sketch?
michaelstranks
Re: Feather M0 RFM95 upload sketch while in low power sleep
by mikeysklar on Mon Oct 18, 2021 6:39 pm
@michaelstranks,
When you want to upload a new sketch would you physically be near the controller where you can double tap the reset button to put it into bootloader mode and upload your sketch?
mikeysklar
