It's Holiday Sale Weekend at Adafruit - use the code ADATY to get 15% off items storewide! Some restrictions apply.
No i2c device at address but code shows the I2C address exis
by sagarpatel1030 on Thu Oct 21, 2021 10:54 pm
hello, I'm just trying to run the stepper motor test on an RP2040 and a stepper motor driver all in circuitpython
when I run an I2C scan I get addresses at 0x60 and 0x70 https://imgur.com/a/OjhQxhm
https://imgur.com/a/l3TvNGE (what I get if I disconnect the motor driver and run the i2c search again)
Then without touching anything I load the simple test code and I get "ValueError: No i2c device at address: 60 " https://imgur.com/a/OtlHhvv\
I have no idea how to fix this, I tried addressing it to 0x60 in an example I saw in another adafruit post but that also gets me nowhere. I have no idea what to do and I've been messing with just trying to get the test code to work for a few hours now.
Any help would be greatly appreciated, sorry this is my first time using python so if its something unbelievably obvious I honestly wouldn't be able to tell
sagarpatel1030
Re: No i2c device at address but code shows the I2C address
by franklin97355 on Thu Oct 21, 2021 11:04 pm
Where did you find that program? The programs I found all say
from adafruit_motorkit import motorkit
kit = MotorKit()
franklin97355
by sagarpatel1030 on Thu Oct 21, 2021 11:38 pm
franklin97355 wrote:Where did you find that program? The programs I found all say
kit = MotorKit()
I found it here at the bottom of the circuitpython usage page as the full example since all I was trying to do was get it to run to make sure it works
https://learn.adafruit.com/adafruit-ste ... cuitpython
If I get rid of the " i2c=board.I2C() " it still says the same thing about no address at 60
sagarpatel1030
by sagarpatel1030 on Sun Oct 24, 2021 6:18 pm
kit = MotorKit()
Finally figured it out, turns out even though the green led was running very bright there wasn't enough power going to it so it wasn't initializing
I was using a battery bank that could output up to 5v at 3Amps but I missed over the fact that it needs a smart signal to max out the power output, so it was probably giving it just enough power to turn the light on and that's it
Plugged it into a continuous 5v 1a power source and problem solved
sagarpatel1030
