I ordered a Adafruit RGB Matrix Featherwing Kit (For RP2040, M0 and M4 Feathers) and the terminal block piece doesn't look like the one on the website and I'm not sure how to use it.
Please advise!
Adafruit RGB Matrix Featherwing Kit Terminal Block?
- TianaCo
- Attachments
- IMG_20211022_170831~2.jpg (244.16 KiB) Viewed 160 times
- dastels
Re: Adafruit RGB Matrix Featherwing Kit Terminal Block?
That looks like a pin jumper , nor a terminal block and I have no idea why it would be with that board. The board should come with the items shown here: https://learn.adafruit.com/assets/59613 Can you post a photo like that so I can see if anything else is off about it?
- TianaCo
These are the pieces it came with. I received the package, I noticed something was off and they resent it and I got the exact same components. I don't think I can use the board without the terminal block. And customer support just sent me here.
- Attachments
- IMG_20211025_115747.jpg (426.76 KiB) Viewed 151 times
- dastels
This is very odd. Can you post a photo of the packaging? There should be a lot/batch number that can be used to investigate the problem. I'm inferring that you have two matrix featherwings, each missing the terminal block? If that's the case please post photos of both pieces packaging, assuming they are still around.
- TianaCo
here are the two bags
- Attachments
- IMG_20211025_153159.jpg (225.24 KiB) Viewed 141 times
- dastels
Thanks. I'll pass that on.
Please email [email protected] with a link to this thread, your order number, and request the "replacement" of two 5.08mm terminal blocks that were missing.
