Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days. On MLK Day no orders will be shipped.
HUZZAH ESP8266 breakout Timed out waiting...
by bujones on Sun Nov 28, 2021 10:35 pm
I'm trying to switch my HUZZAH ESP8266 breakout board to use the Arduino IDE. I have been following the guide at https://learn.adafruit.com/adafruit-huz ... rduino-ide and have the new board loaded into the IDE and when I try and upload the sketch I get the following.
Executable segment sizes:
ICACHE : 32768           - flash instruction cache
IROM   : 231724          - code in flash         (default or ICACHE_FLASH_ATTR)
IRAM   : 26793   / 32768 - code in IRAM          (IRAM_ATTR, ISRs...)
DATA   : 1496  )         - initialized variables (global, static) in RAM/HEAP
RODATA : 876   ) / 81920 - constants             (global, static) in RAM/HEAP
BSS    : 25608 )         - zeroed variables      (global, static) in RAM/HEAP
/Users/bujones/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-size -A /var/folders/bx/gtq_wjjj1t1clxdck0rp3wyr0000gn/T/arduino_build_325178/ESP8266.ino.elf
Sketch uses 260889 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 27980 bytes (34%) of dynamic memory, leaving 53940 bytes for local variables. Maximum is 81920 bytes.
esptool.py v3.0
Serial port /dev/cu.usbserial-AH03IMOT
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 8c:aa:b5:77:2c:78
Uploading stub...
  File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/upload.py", line 66, in <module>
    esptool.main(cmdline)
  File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 3575, in main
    esp = esp.run_stub()
  File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 722, in run_stub
    self.mem_block(stub[field][from_offs:to_offs], seq)
  File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 609, in mem_block
    return self.check_command("write to target RAM", self.ESP_MEM_DATA,
  File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 413, in check_command
    val, data = self.command(op, data, chk, timeout=timeout)
  File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 386, in command
    p = self.read()
  File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 331, in read
    return next(self._slip_reader)
  File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 2636, in slip_reader
    raise FatalError("Timed out waiting for packet %s" % waiting_for)
esptool.FatalError: Timed out waiting for packet header
I can connect to my WiFi using lua without any issues. I have reviewed many other posts regarding this same issue but none of the suggestions in those posts have helped.
I appreciate any assistance.
bujones
Re: HUZZAH ESP8266 breakout Timed out waiting...
by bujones on Mon Nov 29, 2021 10:59 pm
Tonight I tried to upgrade the NodeMCU firmware and it hangs at uploading stub... I then tried to install the MicroPython firmware from Mu and get the same timeout error. I can connect and upload Lua files and execute them without any issues. I'm at a total loss with this.
bujones
by bujones on Tue Dec 21, 2021 12:57 pm
I was abel to get this working by removing the third-party FTDI driver and use the native Mac supported driver.
bujones
