Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days.
Pointing LED Pin to JST on propmaker for neopixels
by HunterDarkwolf on Fri Jan 14, 2022 4:08 pm
I have the Featherwing Propmaker, and one of the Feather boards (Adafruit Feather 32u4 Basic Prot). Just got some JST connectors in so I could hook the neopixels into the propmaker. Currently using the JST PH 2mm 3-pin Plug to Color Coded Alligator Clips Cable, to test that code works before soldering JSTs onto the neopixel strip. However, when I compile and upload code to the board, it uploads, and nothing happens. When I plug the wires directly into the feather's headers (without using the prop maker board) it works. I think some of my issue is that I'm not sure how to point the sketch to the JST/Prop maker board. I'm using the strandtest example. The relevant bit of code is
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1:
#define LED_PIN 5
I've tried pin 1, pin 5, and pin 6 with no results.
HunterDarkwolf
Re: Pointing LED Pin to JST on propmaker for neopixels
by adafruit_support_carter on Fri Jan 14, 2022 5:52 pm
Pinout info is here:
https://learn.adafruit.com/adafruit-pro ... ng/pinouts
You'll need additional code that enables power for the NeoPixels:
https://learn.adafruit.com/adafruit-pro ... 3015804-12
There's an Arduino example here:
https://learn.adafruit.com/adafruit-pro ... duino-code
