I am using FEATHER RFM69HCW modules and one of the FEATHERS(CLIENT)has three pushbuttons which transmit button pushed to the other two FEATHERS(SERVERS). It is important to send the signal to both SERVERS at the same time. The code I have attached works but there is a delay between when the servers get the signal. The code is using addressing with encryption disabled. The total code is attached but the problem area is here(Lines 179-241). Most of the code is from RADIOHEAD examples.
"both = digitalRead(both_pin);
//Serial.print("both_pin = ");Serial.println(both);
if (both == LOW)
char radiopacket[20] = "both_pin";
itoa(packetnum++, radiopacket+13, 10);
Serial.print("Sending both_pin "); Serial.println(radiopacket);
// Send a message!
if (rf69_manager.sendtoWait((uint8_t *)radiopacket, strlen(radiopacket), DEST_ADDRESS_L))
// Now wait for a reply from the server
uint8_t len = sizeof(buf);
uint8_t from;
if (rf69_manager.recvfromAckTimeout(buf, &len, 2000, &from))
buf[len] = 0; // zero out remaining string
//Serial.print("Got reply from #"); Serial.print(from);
//Serial.print(" [RSSI :");
//Serial.print(rf69.lastRssi());
//Serial.print("] : ");
//Serial.println((char*)buf);
//Blink(LED, 40, 3); //blink LED 3 times, 40ms between blinks
else
Serial.println("No reply, is anyone listening?");
else
Serial.println("Sending failed (no ack)");
if (rf69_manager.sendtoWait((uint8_t *)radiopacket, strlen(radiopacket), DEST_ADDRESS_H))
uint8_t from;
else
else
