Board Manager for Arduino_Not seeing Adafruit Boards
by jlcourt on Mon Jan 17, 2022 4:42 pm
I'm returning to microcontrollers after about a 5 year absence (work will do that!) Purchased a featherboard Huzzah32 and am using Arduino IDE 1.8.19 on a Macbook Pro running 10.13.6.
Followed directions from Adafruit to add "Additional Boards" link through Preferences, but don't see any Adafruit Boards listed under "Contributed" pull down menu in Board Manager. Here's link to directions: https://learn.adafruit.com/add-boards-a ... v164/setup
And here is link I copied to "Additional Board Manager URL" (in preferences): https://adafruit.github.io/arduino-boar ... index.json
Did all the usual, downloaded recommended USB driver (it works - was able to test an old Duemilanove board) rebooted, uninstalled and reinstalled Arduino IDE.
I'm a novice so I'm probably missing something simple, but would appreciate someone telling me where I went wrong.
jlcourt
Re: Board Manager for Arduino_Not seeing Adafruit Boards
by mikeysklar on Tue Jan 18, 2022 7:32 pm
The Huzzah32 is an outlier as it uses the espressif/arduino-esp32 repository. There are instructions here for it.
https://github.com/espressif/arduino-es ... rduino-ide
In general though to see almost all of our other boards (AVR/SAMD) based you have done the correct steps. You then need to go to Arduino --> Tools --> Board --> Board Manager and install the appropriate package for your controller.
mikeysklar
by jlcourt on Sat Jan 29, 2022 8:23 pm
Thanks Mikey - will work my way through that information!
jlcourt
