The Feather ESP32-S2 TFT ships with a demo running. Is example code available for this demo?
Feather ESP32-S2 TFT Demo code
- legowerewolf
Re: Feather ESP32-S2 TFT Demo code
Seconding this. Can't work out how to control the display from CircuitPython.
- adamhi
Stumped here as well. I was pretty excited about using this board, but the frustration level is rising.
The display will echo what i'm typing and seeing in the REPL, so i know that it at least works since putting on CircuitPython. I also tried the example code from the related TFT breakout board (Product ID: 4383) to work - no joy. I have updated to CircuitPython 7.2.0 Alpha 1, which supposedly added the support for this board.
I hope something positive and constructive appears here soon.
EDIT: Addendum: Happy Happy Joy Joy
In searching through MORE of the forum, i found post viewtopic.php?f=60&t=187107&p=906439&hi ... er#p906203 .
The solution is there, and summarized here:
Use the example code in the product i mentioned above, and update to CircuitPython 7.2.0 Alpha
Comment out the following lines:
and after the
--adam
from adafruit_st7789 import ST7789
displayio.release_displays()
spi = board.SPI()
display_bus = displayio.FourWire(spi, command=tft_dc, chip_select=tft_cs)
display = ST7789(
display_bus, rotation=270, width=240, height=135, rowstart=40, colstart=53
- tft_cs = board.D5
tft_dc = board.D6
display = board.DISPLAY
- legowerewolf
@adamhi thanks!
- mushburger
Does anyone have any clues on how to communicate to the TFT display on this board using Arduino code instead of CircuitPython?
- Brezensalzer
@mushburger
You could try the TFT_eSPI library, checkout https://github.com/Bodmer/TFT_eSPI
I made a pull request (merged) to get my QtPy ESP32-S2 running with a tft display.
You have to in User_Setup.h.
You have to
#define USE_FSPI_PORT
- mushburger
Thanks @Brezensalzer
I was able to get something working. The critical information I needed ultimately came from the pinout diagram on the Adafruit product write-up... RTFM!!
Below is the code I used to get something working. The secret was to know which pins needed to be set for TFT_CS, TFT_DC, and TFT_RST. Then I just needed to figure out what pins to set high to turn on the I2C and the backlight. Then it was pretty easy to work with.
// Libraries
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
/******************* TFT Display **********************/
#define TFT_CS 7
#define TFT_DC 39
#define TFT_RST 40
#define TFT_I2C_POWER 21
#define TFT_BACKLIGHT 45
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
// -------------------------PROGRAM---------------------------
void setup()
// Set up the Serial port
// - Not critical, used for debugging
Serial.begin(9600);
for(int x = 0; x < 250; x++){
if(!Serial){
delay(10);
continue;
}else{
break;
// TFT Display
pinMode(TFT_I2C_POWER, OUTPUT);
pinMode(TFT_BACKLIGHT, OUTPUT);
tft.init(135, 240); // Initialize
tft.fillScreen(ST77XX_BLACK); // Clear the screen
tft.setRotation(3);
digitalWrite(TFT_I2C_POWER, HIGH);
digitalWrite(TFT_BACKLIGHT, HIGH);
// Print some data on the TFT display
tftPrintTest();
void loop()
void testdrawtext(char *text, uint16_t color) {
tft.setCursor(0, 0);
tft.setTextColor(color);
tft.setTextWrap(true);
tft.print(text);
void tftPrintTest() {
tft.setTextWrap(false);
tft.setCursor(0, 30);
tft.setTextColor(ST77XX_RED);
tft.setTextSize(1);
tft.println("Hello World!");
tft.setTextColor(ST77XX_YELLOW);
tft.setTextSize(2);
tft.setTextColor(ST77XX_GREEN);
tft.setTextSize(3);
tft.setTextColor(ST77XX_BLUE);
tft.setTextSize(4);
tft.print(1234.567);
delay(1500);
tft.setTextColor(ST77XX_WHITE);
tft.setTextSize(0);
tft.setTextSize(1);
tft.print(3.1415926, 6);
tft.println(" Want pi?");
tft.println(" ");
tft.print(8675309, HEX); // print 8,675,309 out in HEX!
tft.println(" Print HEX!");
tft.println(" ");
tft.println("Sketch has been");
tft.println("running for: ");
tft.setTextColor(ST77XX_MAGENTA);
tft.print(millis() / 1000);
tft.print(" seconds.");
- ryan780
As long as you are using the latest version of the ESP32 library and have selected the ESP32 S2 TFT from the board menu, you don't have to strictly define those pins or the TFT_I2C_POWER or TFT_BACKLITE. They are all defined in the board definition file.mushburger wrote:Thanks @Brezensalzer
#define TFT_CS 7
#define TFT_RST 40
#define TFT_DC 39
#define TFT_BACKLITE 45
The one thing your code is missing to get the display to work is the enable command
tft.enableDisplay (true);
This is a library for several Adafruit displays based on ST77* drivers.
products from Adafruit!
MIT license, all text above must be included in any redistribution
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#include <SPI.h>
float p = 3.1415926;
void setup(void) {
Serial.begin(115200);
Serial.print(F("Hello! ST77xx TFT Test"));
pinMode(TFT_I2C_POWER,OUTPUT);
pinMode(TFT_BACKLITE, OUTPUT);
digitalWrite(TFT_BACKLITE, HIGH);
tft.init(135, 240); // Init ST7789 240x135
tft.setRotation(3);
Serial.println("Initialized");
uint16_t time = millis();
time = millis() - time;
tft.enableDisplay(true);
Serial.println(time, DEC);
delay(500);
// large block of text
testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", ST77XX_WHITE);
delay(1000);
// tft print function!
tftPrintTest();
delay(4000);
// a single pixel
tft.drawPixel(tft.width()/2, tft.height()/2, ST77XX_GREEN);
delay(500);
// line draw test
testlines(ST77XX_YELLOW);
delay(500);
// optimized lines
testfastlines(ST77XX_RED, ST77XX_BLUE);
delay(500);
testdrawrects(ST77XX_GREEN);
delay(500);
testfillrects(ST77XX_YELLOW, ST77XX_MAGENTA);
delay(500);
testfillcircles(10, ST77XX_BLUE);
testdrawcircles(10, ST77XX_WHITE);
delay(500);
testroundrects();
delay(500);
testtriangles();
delay(500);
mediabuttons();
delay(500);
Serial.println("done");
delay(1000);
tft.invertDisplay(true);
delay(500);
tft.invertDisplay(false);
delay(500);
void testlines(uint16_t color) {
for (int16_t x=0; x < tft.width(); x+=6) {
tft.drawLine(0, 0, x, tft.height()-1, color);
delay(0);
for (int16_t y=0; y < tft.height(); y+=6) {
tft.drawLine(0, 0, tft.width()-1, y, color);
delay(0);
tft.drawLine(tft.width()-1, 0, x, tft.height()-1, color);
delay(0);
tft.drawLine(tft.width()-1, 0, 0, y, color);
delay(0);
tft.drawLine(0, tft.height()-1, x, 0, color);
delay(0);
tft.drawLine(0, tft.height()-1, tft.width()-1, y, color);
delay(0);
tft.drawLine(tft.width()-1, tft.height()-1, x, 0, color);
delay(0);
tft.drawLine(tft.width()-1, tft.height()-1, 0, y, color);
delay(0);
void testdrawtext (char *text, uint16_t color) {
tft.print(text);
void testfastlines(uint16_t color1, uint16_t color2) {
for (int16_t y=0; y < tft.height(); y+=5) {
tft.drawFastHLine(0, y, tft.width(), color1);
for (int16_t x=0; x < tft.width(); x+=5) {
tft.drawFastVLine(x, 0, tft.height(), color2);
void testdrawrects(uint16_t color) {
tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
for (int16_t x=tft.width()-1; x > 6; x-=6) {
tft.fillRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color1);
tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
for (int16_t x=radius; x < tft.width(); x+=radius*2) {
for (int16_t y=radius; y < tft.height(); y+=radius*2) {
tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
for (int16_t x=0; x < tft.width()+radius; x+=radius*2) {
for (int16_t y=0; y < tft.height()+radius; y+=radius*2) {
tft.drawCircle(x, y, radius, color);
void testtriangles() {
uint16_t color = 0xF800;
int t;
int w = tft.width()/2;
int x = tft.height()-1;
int y = 0;
int z = tft.width();
for(t = 0 ; t <= 15; t++) {
tft.drawTriangle(w, y, y, x, z, x, color);
x-=4;
y+=4;
z-=4;
color+=100;
void testroundrects() {
uint16_t color = 100;
int i;
int t;
for(t = 0 ; t <= 4; t+=1) {
int x = 0;
int y = 0;
int w = tft.width()-2;
int h = tft.height()-2;
for(i = 0 ; i <= 16; i+=1) {
tft.drawRoundRect(x, y, w, h, 5, color);
x+=2;
y+=3;
w-=4;
h-=6;
color+=1100;
color+=100;
tft.setTextSize(1);
tft.setTextSize(2);
tft.setTextSize(3);
tft.setTextSize(4);
delay(1500);
tft.setTextSize(0);
tft.setTextSize(1);
tft.print(p, 6);
tft.println(" ");
tft.println(" ");
void mediabuttons() {
// play
tft.fillRoundRect(25, 10, 78, 60, 8, ST77XX_WHITE);
tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_RED);
delay(500);
// pause
tft.fillRoundRect(25, 90, 78, 60, 8, ST77XX_WHITE);
tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_GREEN);
tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_GREEN);
delay(500);
// play color
tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_BLUE);
delay(50);
// pause color
tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_RED);
tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_RED);
// play color
tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_GREEN);
- freddyboomboom
I don't have one, but I would start at the guide: https://learn.adafruit.com/adafruit-esp ... tft-basics
they have a section on using Arduino, too: https://learn.adafruit.com/adafruit-esp ... ilt-in-tft
- ryan780
But there is no example using the TFT screen. Trust me, I have looked. :-)
- freddyboomboom
Well, I linked to the sections titled "TFT Basics" and "Built in TFT".
The code section in the Circuitpython part that displays "Hello World!" on the TFT works on my Funhouse to display on the TFT. So "board.DISPLAY.show" works for me.
Sorry I can't help more.
- ryan780
Again, that's for circuit python. But the example I listed above works. That should answer the question I believe.
