I'm using a feather M0 (with RFM69 radio) with an I2S microphone breakout: https://www.adafruit.com/product/3421
I'm following this tutorial: https://learn.adafruit.com/adafruit-i2s ... -breakout/
The question I have is: can the data out pin be connected to any other pin apart from pin 9? I already have pin 9 in my circuit used for something else and it would be convenient if I can simply change this in the library, but I do not see an option for setting this pin anywhere.
Feather M0 I2S pin
- adafruit_support_carter
Re: Feather M0 I2S pin
Unfortunately, no. The output uses the I2S peripheral on the SAMD21, which is only available on specific pins.
- AKstudios
Thanks for the reply. As far as I can see, the SAMD21 has a 2 channel I2S peripheral. There are two SD pins on the chip: https://ww1.microchip.com/downloads/en/ ... 01882F.pdf
Even on the feather, it is marked on the pinout diagram here: https://cdn-learn.adafruit.com/assets/a ... 1504886606
I2SD0 is on pin 9 as well as pin 12.
So this theoretically can be changed, it just looks like it's hard-coded to pin 9 either in the library or the board definition somewhere, not sure.
I would like to know if it's possible to change it from pin 9 to pin 12.
Correct.So this theoretically can be changed, it just looks like it's hard-coded to pin 9 either in the library or the board definition somewhere, not sure.
Not seeing any reference to this in the documentation:
https://www.arduino.cc/en/Reference/I2S
but looking at the source code, it appears the constructor can take additional parameters:
https://github.com/arduino/ArduinoCore- ... /I2S.h#L38
So there may be a way? Just not available on *any* pins.
- AKstudios
Yes, you're correct, it's not *any* pin, just the ones that can be used for the I2S peripheral.
In the library you shared, it's not very apparent where those pins are defined. If I have to change it, would it be a board definition change? I don't see where the constructor is pulling the sdPin from.
