Feather ESP32-S2 TFT Demo code
Re: Feather ESP32-S2 TFT Demo code
from adafruit_st7789 import ST7789
displayio.release_displays()
spi = board.SPI()
display_bus = displayio.FourWire(spi, command=tft_dc, chip_select=tft_cs)
display = ST7789(
display_bus, rotation=270, width=240, height=135, rowstart=40, colstart=53
display = board.DISPLAY
#define USE_FSPI_PORT
// Libraries
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
/******************* TFT Display **********************/
#define TFT_CS 7
#define TFT_DC 39
#define TFT_RST 40
#define TFT_I2C_POWER 21
#define TFT_BACKLIGHT 45
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
// -------------------------PROGRAM---------------------------
void setup()
// Set up the Serial port
// - Not critical, used for debugging
Serial.begin(9600);
for(int x = 0; x < 250; x++){
if(!Serial){
delay(10);
continue;
}else{
break;
// TFT Display
pinMode(TFT_I2C_POWER, OUTPUT);
pinMode(TFT_BACKLIGHT, OUTPUT);
tft.init(135, 240); // Initialize
tft.fillScreen(ST77XX_BLACK); // Clear the screen
tft.setRotation(3);
digitalWrite(TFT_I2C_POWER, HIGH);
digitalWrite(TFT_BACKLIGHT, HIGH);
// Print some data on the TFT display
tftPrintTest();
void loop()
void testdrawtext(char *text, uint16_t color) {
tft.setCursor(0, 0);
tft.setTextColor(color);
tft.setTextWrap(true);
tft.print(text);
void tftPrintTest() {
tft.setTextWrap(false);
tft.setCursor(0, 30);
tft.setTextColor(ST77XX_RED);
tft.setTextSize(1);
tft.println("Hello World!");
tft.setTextColor(ST77XX_YELLOW);
tft.setTextSize(2);
tft.setTextColor(ST77XX_GREEN);
tft.setTextSize(3);
tft.setTextColor(ST77XX_BLUE);
tft.setTextSize(4);
tft.print(1234.567);
delay(1500);
tft.setTextColor(ST77XX_WHITE);
tft.setTextSize(0);
tft.setTextSize(1);
tft.print(3.1415926, 6);
tft.println(" Want pi?");
tft.println(" ");
tft.print(8675309, HEX); // print 8,675,309 out in HEX!
tft.println(" Print HEX!");
tft.println(" ");
tft.println("Sketch has been");
tft.println("running for: ");
tft.setTextColor(ST77XX_MAGENTA);
tft.print(millis() / 1000);
tft.print(" seconds.");
mushburger wrote:Thanks @Brezensalzer
The secret was to know which pins needed to be set for TFT_CS, TFT_DC, and TFT_RST.
#define TFT_CS 7
#define TFT_RST 40
#define TFT_DC 39
#define TFT_BACKLITE 45
tft.enableDisplay (true);
This is a library for several Adafruit displays based on ST77* drivers.
products from Adafruit!
MIT license, all text above must be included in any redistribution
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#include <SPI.h>
float p = 3.1415926;
void setup(void) {
Serial.begin(115200);
Serial.print(F("Hello! ST77xx TFT Test"));
pinMode(TFT_I2C_POWER,OUTPUT);
pinMode(TFT_BACKLITE, OUTPUT);
digitalWrite(TFT_BACKLITE, HIGH);
tft.init(135, 240); // Init ST7789 240x135
tft.setRotation(3);
Serial.println("Initialized");
uint16_t time = millis();
time = millis() - time;
tft.enableDisplay(true);
Serial.println(time, DEC);
delay(500);
// large block of text
testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", ST77XX_WHITE);
delay(1000);
// tft print function!
tftPrintTest();
delay(4000);
// a single pixel
tft.drawPixel(tft.width()/2, tft.height()/2, ST77XX_GREEN);
delay(500);
// line draw test
testlines(ST77XX_YELLOW);
delay(500);
// optimized lines
testfastlines(ST77XX_RED, ST77XX_BLUE);
delay(500);
testdrawrects(ST77XX_GREEN);
delay(500);
testfillrects(ST77XX_YELLOW, ST77XX_MAGENTA);
delay(500);
testfillcircles(10, ST77XX_BLUE);
testdrawcircles(10, ST77XX_WHITE);
delay(500);
testroundrects();
delay(500);
testtriangles();
delay(500);
mediabuttons();
delay(500);
Serial.println("done");
delay(1000);
tft.invertDisplay(true);
delay(500);
tft.invertDisplay(false);
delay(500);
void testlines(uint16_t color) {
for (int16_t x=0; x < tft.width(); x+=6) {
tft.drawLine(0, 0, x, tft.height()-1, color);
delay(0);
for (int16_t y=0; y < tft.height(); y+=6) {
tft.drawLine(0, 0, tft.width()-1, y, color);
delay(0);
tft.drawLine(tft.width()-1, 0, x, tft.height()-1, color);
delay(0);
tft.drawLine(tft.width()-1, 0, 0, y, color);
delay(0);
tft.drawLine(0, tft.height()-1, x, 0, color);
delay(0);
tft.drawLine(0, tft.height()-1, tft.width()-1, y, color);
delay(0);
tft.drawLine(tft.width()-1, tft.height()-1, x, 0, color);
delay(0);
tft.drawLine(tft.width()-1, tft.height()-1, 0, y, color);
delay(0);
void testdrawtext (char *text, uint16_t color) {
tft.print(text);
void testfastlines(uint16_t color1, uint16_t color2) {
for (int16_t y=0; y < tft.height(); y+=5) {
tft.drawFastHLine(0, y, tft.width(), color1);
for (int16_t x=0; x < tft.width(); x+=5) {
tft.drawFastVLine(x, 0, tft.height(), color2);
void testdrawrects(uint16_t color) {
tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
for (int16_t x=tft.width()-1; x > 6; x-=6) {
tft.fillRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color1);
tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
for (int16_t x=radius; x < tft.width(); x+=radius*2) {
for (int16_t y=radius; y < tft.height(); y+=radius*2) {
tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
for (int16_t x=0; x < tft.width()+radius; x+=radius*2) {
for (int16_t y=0; y < tft.height()+radius; y+=radius*2) {
tft.drawCircle(x, y, radius, color);
void testtriangles() {
uint16_t color = 0xF800;
int t;
int w = tft.width()/2;
int x = tft.height()-1;
int y = 0;
int z = tft.width();
for(t = 0 ; t <= 15; t++) {
tft.drawTriangle(w, y, y, x, z, x, color);
x-=4;
y+=4;
z-=4;
color+=100;
void testroundrects() {
uint16_t color = 100;
int i;
int t;
for(t = 0 ; t <= 4; t+=1) {
int x = 0;
int y = 0;
int w = tft.width()-2;
int h = tft.height()-2;
for(i = 0 ; i <= 16; i+=1) {
tft.drawRoundRect(x, y, w, h, 5, color);
x+=2;
y+=3;
w-=4;
h-=6;
color+=1100;
color+=100;
tft.setTextSize(1);
tft.setTextSize(2);
tft.setTextSize(3);
tft.setTextSize(4);
delay(1500);
tft.setTextSize(0);
tft.setTextSize(1);
tft.print(p, 6);
tft.println(" ");
tft.println(" ");
void mediabuttons() {
// play
tft.fillRoundRect(25, 10, 78, 60, 8, ST77XX_WHITE);
tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_RED);
delay(500);
// pause
tft.fillRoundRect(25, 90, 78, 60, 8, ST77XX_WHITE);
tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_GREEN);
tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_GREEN);
delay(500);
// play color
tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_BLUE);
delay(50);
// pause color
tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_RED);
tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_RED);
// play color
tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_GREEN);
