Issue with Prop Maker, M4, and NeoPixel
Re: Issue with Prop Maker, M4, and NeoPixel
"""LASER SWORD (pew pew) example for Adafruit Hallowing & NeoPixel strip"""
# pylint: disable=bare-except
import time
import math
import gc
from digitalio import DigitalInOut, Direction, Pull
import audioio
import audiocore
import busio
import board
import neopixel
import adafruit_lis3dh
# Added
from adafruit_debouncer import Debouncer
# CUSTOMIZE YOUR COLOR HERE:
# (red, green, blue) -- each 0 (off) to 255 (brightest)
COLOR = (255, 0, 0) # red
# COLOR = (0, 255, 0) # green
# COLOR = (100, 0, 255) # purple
# COLOR = (255, 20, 147) # deeppink
# COLOR = (0, 100, 255) # cyan
# Added: Custom Color Array Setup
# array setup:
# custColor[0] = (ccr[0],ccg[0],ccb[0]) = red
# custColor[1] = (ccr[1],ccg[1],ccb[1]) = green
# custColor[2] = (ccr[2],ccg[2],ccb[2]) = blue
# custColor[3] = (ccr[3],ccg[3],ccb[3]) = purple
# custColor[4] = (ccr[4],ccg[4],ccb[4]) = deeppink
ccr = [255, 0, 0, 100, 255]
ccg = [0, 255, 0, 0, 20]
ccb = [0, 0, 255, 255, 147]
cc = 0
# CUSTOMIZE SENSITIVITY HERE: smaller numbers = more sensitive to motion
HIT_THRESHOLD = 350 # 250
SWING_THRESHOLD = 125
# Defining number of Pixels
bldLen = 1 # blade length in meters
pixPerMtr = 144 # Neopixel per meter (from mfg)
NUM_PIXELS = pixPerMtr // bldLen
# NUM_PIXELS = 114
# NUM_PIXELS = 85
NEOPIXEL_PIN = board.D5
POWER_PIN = board.D10
SWITCH_PIN = board.D9
# Added
# COLOR_PIN = board.D8
enable = DigitalInOut(POWER_PIN)
enable.direction = Direction.OUTPUT
enable.value = False
red_led = DigitalInOut(board.D11)
red_led.direction = Direction.OUTPUT
green_led = DigitalInOut(board.D12)
green_led.direction = Direction.OUTPUT
blue_led = DigitalInOut(board.D13)
blue_led.direction = Direction.OUTPUT
audio = audioio.AudioOut(board.A0) # Speaker
mode = 0 # Initial mode = OFF
strip = neopixel.NeoPixel(NEOPIXEL_PIN, NUM_PIXELS, brightness=1, auto_write=False)
strip.fill(0) # NeoPixels off ASAP on startup
strip.show()
switch = DigitalInOut(SWITCH_PIN)
switch.direction = Direction.INPUT
switch.pull = Pull.UP
# Added
# bldClr = DigitalInOut(COLOR_PIN)
# bldClr.direction = Direction.INPUT
# bldClr.pull = Pull.UP
# bladeColorPb = Debouncer(bldClr)
time.sleep(0.1)
# Set up accelerometer on I2C bus, 4G range:
i2c = busio.I2C(board.SCL, board.SDA)
accel = adafruit_lis3dh.LIS3DH_I2C(i2c)
accel.range = adafruit_lis3dh.RANGE_4_G
# "Idle" color is 1/4 brightness, "swinging" color is full brightness...
COLOR_IDLE = (int(COLOR[0] / 1), int(COLOR[1] / 1), int(COLOR[2] / 1))
COLOR_SWING = COLOR
COLOR_HIT = (255, 255, 255) # "hit" color is white
def play_wav(name, loop=False):
Play a WAV file in the 'sounds' directory.
@param name: partial file name string, complete name will be built around
this, e.g. passing 'foo' will play file 'sounds/foo.wav'.
@param loop: if True, sound will repeat indefinitely (until interrupted
by another sound).
print("playing", name)
try:
wave_file = open("sounds/" + name + ".wav", "rb")
wave = audiocore.WaveFile(wave_file)
audio.play(wave, loop=loop)
except:
return
def power(sound, duration, reverse):
Animate NeoPixels with accompanying sound effect for power on / off.
@param sound: sound name (similar format to play_wav() above)
@param duration: estimated duration of sound, in seconds (>0.0)
@param reverse: if True, do power-off effect (reverses animation)
if reverse:
prev = NUM_PIXELS
else:
prev = 0
gc.collect() # Clean RAM so animation smooth
start_time = time.monotonic() # Save audio start time
play_wav(sound)
while True:
elapsed = time.monotonic() - start_time # Time spent playing sound
if elapsed > duration: # Past sound duration?
break # Stop animating
fraction = elapsed / duration # Animation time, 0.0 to 1.0
if reverse:
fraction = 1.0 - fraction # 1.0 to 0.0 if reverse
fraction = math.pow(fraction, 0.5) # Apply nonlinear curve
threshold = int(NUM_PIXELS * fraction + 0.5)
num = threshold - prev # Qty pixels to light on pass
if num != 0:
if reverse:
strip[threshold:prev] = [0] * -num
else:
strip[prev:threshold] = [COLOR_IDLE] * num
strip.show()
# NeoPixel writes throw off time.monotonic() ever so slightly
# because interrupts are disabled during the transfer.
# We can compensate somewhat by adjusting the start time
# back by 30 microseconds per pixel.
start_time -= NUM_PIXELS * 0.00003
prev = threshold
if reverse:
strip.fill(0) # At end, ensure strip is off
else:
strip.fill(COLOR_IDLE) # or all pixels set on
strip.show()
while audio.playing: # Wait until audio done
pass
def mix(color_1, color_2, weight_2):
Blend between two colors with a given ratio.
@param color_1: first color, as an (r,g,b) tuple
@param color_2: second color, as an (r,g,b) tuple
@param weight_2: Blend weight (ratio) of second color, 0.0 to 1.0
@return: (r,g,b) tuple, blended color
if weight_2 < 0.0:
weight_2 = 0.0
elif weight_2 > 1.0:
weight_2 = 1.0
weight_1 = 1.0 - weight_2
return (
int(color_1[0] * weight_1 + color_2[0] * weight_2),
int(color_1[1] * weight_1 + color_2[1] * weight_2),
int(color_1[2] * weight_1 + color_2[2] * weight_2),
# Main program loop, repeats indefinitely
while True:
# Added
# bldClr.update()
red_led.value = True
if not switch.value: # button pressed?
if mode == 0: # If currently off...
enable.value = True
power("on", 1.7, False) # Power up!
play_wav("idle", loop=True) # Play background hum sound
mode = 1 # ON (idle) mode now
else: # else is currently on...
power("off", 1.15, True) # Power down
mode = 0 # OFF mode now
while not switch.value: # Wait for button release
time.sleep(0.2) # to avoid repeated triggering
elif mode >= 1: # If not OFF mode...
x, y, z = accel.acceleration # Read accelerometer
accel_total = x * x + z * z
# (Y axis isn't needed for this, assuming Hallowing is mounted
# sideways to stick. Also, square root isn't needed, since we're
# just comparing thresholds...use squared values instead, save math.)
if accel_total > HIT_THRESHOLD: # Large acceleration = HIT
TRIGGER_TIME = time.monotonic() # Save initial time of hit
play_wav("hit") # Start playing 'hit' sound
COLOR_ACTIVE = COLOR_HIT # Set color to fade from
mode = 3 # HIT mode
elif mode == 1 and accel_total > SWING_THRESHOLD: # Mild = SWING
TRIGGER_TIME = time.monotonic() # Save initial time of swing
play_wav("swing") # Start playing 'swing' sound
COLOR_ACTIVE = COLOR_SWING # Set color to fade from
mode = 2 # SWING mode
elif mode > 1: # If in SWING or HIT mode...
if audio.playing: # And sound currently playing..
blend = time.monotonic() - TRIGGER_TIME # Time since triggered
if mode == 2: # If SWING,
blend = abs(0.5 - blend) * 2.0 # ramp up, down
strip.fill(mix(COLOR_ACTIVE, COLOR_IDLE, blend))
strip.show()
else: # No sound now, MODE > 1
play_wav("idle", loop=True) # Resume background hum
strip.fill(COLOR_IDLE) # Set to idle color
strip.show()
mode = 1 # IDLE mode now
# Added
# if bladeColorPb.fell: # When colorchange PB pressed
# cc += 1
# if cc >= len(ccr):
# cc = 0 # reset index to 0
# COLOR = (ccr[cc], ccg[cc], ccb[cc])
