Feather M4 CAN CANBUS Stopped working?
davidthefuturist
Post by davidthefuturist »
Hey guys, I got both my Feather M4 CAN units to successfully talk to one another at one point a few days ago, but now they no longer seem to talk to one another.
Here are both sketches. Both are unmodified code I got from here: https://learn.adafruit.com/adafruit-fea ... n-examples
Send:
// Copyright (c) Sandeep Mistry. All rights reserved.
// Licensed under the MIT license. See LICENSE file in the project root for full license information.
#include <CAN.h>
  Serial.begin(9600);
  while (!Serial);
  Serial.println("CAN Sender");
  pinMode(PIN_CAN_STANDBY, OUTPUT);
  digitalWrite(PIN_CAN_STANDBY, false); // turn off STANDBY
  pinMode(PIN_CAN_BOOSTEN, OUTPUT);
  digitalWrite(PIN_CAN_BOOSTEN, true); // turn on booster
  // start the CAN bus at 250 kbps
  if (!CAN.begin(250000)) {
    Serial.println("Starting CAN failed!");
    while (1);
  // send packet: id is 11 bits, packet can contain up to 8 bytes of data
  Serial.print("Sending packet ... ");
  CAN.beginPacket(0x12);
  CAN.write('h');
  CAN.write('e');
  CAN.write('l');
  CAN.write('l');
  CAN.write('o');
  CAN.endPacket();
  Serial.println("done");
  delay(1000);
  // send extended packet: id is 29 bits, packet can contain up to 8 bytes of data
  Serial.print("Sending extended packet ... ");
  CAN.beginExtendedPacket(0xabcdef);
  CAN.write('w');
  CAN.write('o');
  CAN.write('r');
  CAN.write('l');
  CAN.write('d');
  CAN.endPacket();
  delay(1000);
Receive:
#include <CAN.h>
  Serial.begin(9600);
  while (!Serial);
  Serial.println("CAN Receiver");
    while (1);
  // try to parse packet
  int packetSize = CAN.parsePacket();
  if (packetSize) {
    // received a packet
    Serial.print("Received ");
    if (CAN.packetExtended()) {
      Serial.print("extended ");
    if (CAN.packetRtr()) {
      // Remote transmission request, packet contains no data
      Serial.print("RTR ");
    Serial.print("packet with id 0x");
    Serial.print(CAN.packetId(), HEX);
      Serial.print(" and requested length ");
      Serial.println(CAN.packetDlc());
    } else {
      Serial.print(" and length ");
      Serial.println(packetSize);
      // only print packet data for non-RTR packets
      while (CAN.available()) {
        Serial.print((char)CAN.read());
      Serial.println();
    Serial.println();
Here's a picture of my system: https://drive.google.com/file/d/1Aahk9c ... sp=sharing
In Arduino IDE's library files, I moved the original CAN library to a folder titled "!Depreciated" and imported Adafruit's provided CAN library. I checked for continuity of the CAN High and CAN Low lines and both seem to have continuity with the respective line.
I tried writing Send to Feather M4 CAN "A" and Receive to Feather M4 CAN "B", as well as writing Feather M4 CAN "B" and Receive to Feather M4 CAN "A", but the same behavior persists.
Current behavior:
Sender tells me in serial monitor:
CAN Sender
Sending packet ... done
Sending extended packet ... done
Receiver tells me "CAN Receiver" in the serial monitor and nothing else
Expected Behavior:
CAN Sender
Receiver tells me "CAN Receiver" in the serial monitor and "hello" "world" in addresses 0x12 and 0xabcdef respectively
Again, I was able to get them to successfully talk to one another a few days ago in the duration I tested them with the correct messages being sent from the sender and seen in the serial monitor of the receiver. Is it possible that I burned something out? How would I be able to test that? Are both of mine defective?
adafruit_support_mike
Re: Feather M4 CAN CANBUS Stopped working?
If you had a working connection to start with, we can probably rule out hardware failures.
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
