On Saturday, August 13, 2022 we will be working on the Adafruit Customer Support Forums. If you visit over the weekend and things are not complete yet, please check back later, https://adafruit.com/forumupdates
upload sketches to M0 Express
by earthres on Tue Jun 28, 2022 10:35 am
I HOPE this isn't a dumb question, but I can't get the M0 Express to upload ANY sketches. As far as I know I've installed all the the required board support. I've tried pushing the reset button twice. What am I doing wrong here??
earthres
Re: upload sketches to M0 Express
by adafruit_support_carter on Tue Jun 28, 2022 10:46 am
What error messages are you seeing when you try to upload?
by earthres on Tue Jun 28, 2022 11:12 am
Here's an image. Hope you can read it!
earthres
by adafruit_support_carter on Tue Jun 28, 2022 11:26 am
It's saying "Port busy" which typically means some other software is claiming the COM port.
Have you ever uploaded to an Arduino board on that PC?
by earthres on Tue Jun 28, 2022 12:30 pm
I've used this Windows 10 computer for YEARS, with many different Arduinos, your HUZZAH32-ESP32, and others. This is the only board I've had problems with. I'm currently using IDE 1.8.15 and I don't have any current plans to change over to the 2. IDE.
earthres
by adafruit_support_carter on Tue Jun 28, 2022 12:43 pm
OK, so other boards upload OK. ESP32 boards have a slightly different interface, which could be why they are working. Have you used any other M0 based boards?
Can you check COM10 in Device Manager and see if its reporting any issues there?
by earthres on Tue Jun 28, 2022 12:56 pm
I haven't used any other M0 board. Device Manager says COM10 is "working properly." This window opens when I try to upload anything to the M0Express.
earthres
by adafruit_support_carter on Tue Jun 28, 2022 1:30 pm
That's the bootloader mode folder. So it's at least getting into bootloader mode.
Does that folder eventually go away? Or does it stay like that after the failed upload?
by earthres on Tue Jun 28, 2022 2:39 pm
The folder doesn't go away unless I close it myself.
earthres
by freddyboomboom on Tue Jun 28, 2022 5:04 pm
I noticed that in your first screenshot in your original post, you have the Arduino M0 selected as the board.
You should probably select Adafruit M0 Express or something like that, instead.
I don't use Arduino, so I don't have any other suggestions, sorry.
freddyboomboom
by earthres on Tue Jun 28, 2022 5:27 pm
Hmm... Considering that you don't use Arduinos at all, why did you make this comment?? Support for all the "Adafruit SAMD Boards" specifically includes the Feather M0 Express. Once this support package is installed, there are three possible choices for M0 boards and I've tried all of them.
earthres
by adafruit_support_carter on Tue Jun 28, 2022 5:29 pm
@freddyboomboom OMG thanks! That's probably it. Missed it looking at the labels in the port menu select.
@earthres Yep, make sure the board selection is for the Feather M0 Express.
https://learn.adafruit.com/adafruit-fea ... rduino-ide
Should be under:
Tools -> Board -> Adafruit SAMD (32-bits ARM Cortex-M0+ and Cortex-M4) Boards
by earthres on Tue Jun 28, 2022 6:36 pm
Here are the available boards from IDE 1.8.15
earthres
by adafruit_support_carter on Tue Jun 28, 2022 7:11 pm
Also install Adafruit SAMD:
https://learn.adafruit.com/adafruit-fea ... md-2854160
You only have Arduino SAMD.
URL to add is shown here:
https://learn.adafruit.com/adafruit-fea ... -ide-setup
by earthres on Tue Jun 28, 2022 7:21 pm
Well, that really was the problem! My bad, and thanks for your patience!
earthres
